trans won't downshift...
Old Jul 14, 2001 | 10:33 PM
rwjr's Avatar
rwjr
78 bronco, c6 trans...just bought a new stock one and put i na B&M shift kit....it won't downshift on it's own....and when i start off again, it only d/shifts to 2nd when i hit the gas....the modulator is getting plent of vac....it is adjustable, but the trans was dyno'd before i bought it....the B&M directions didn't say anything about adjusting it, but might it fix the problem to adjust the modulator?????
Old Jul 15, 2001 | 12:38 AM
Ratsmoker's Avatar
Ratsmoker
Is your kickdown linkage hooked up? It is the lever on the drivers side of your tranny right by the gear selector lever. You can adjust the modulator all day long but if your kick down lever isn't moving your not going to get a downshift.
Old Jul 15, 2001 | 11:13 AM
mattb's Avatar
mattb
the kickdown linkage has nothing to do with it downshifting when you come to a stop.it is the valve body. drop the pan, take out the valve body and make sure you did everything correct, when you installed the shift kit. where did you get the trans from? is it possible it already had a shift kit in it? or an aftermarket valve body?
matt
Old Jul 15, 2001 | 05:03 PM
rwjr's Avatar
rwjr
i got it from advance...a remanufactured one....the info sheet talks about the dynoing and all....and the valve body had no mods....i bought a TCI valve body from PAW...it was only $125, so i said heck with it...just get one i know is right....i think a bolt may have stripped in the old one.....this'll take care of that problem easily.....
Old Jul 15, 2001 | 09:59 PM
thelonerangerxlt's Avatar
thelonerangerxlt
luthoro
Jul 19, 2013 07:44 PM
underthebridgejim
30
Jun 15, 2013 01:33 PM
TheKirbyMan
18
Jan 10, 2012 01:04 AM
oldcoupe42
Jun 22, 2009 03:27 PM
Ford79
Dec 21, 2002 10:50 PM
