Sponsored by: Innova
frequency settings?
Old Jan 30, 2006 | 08:37 PM
voodoosurfer's Avatar
voodoosurfer
frequency settings?
Ok I have a pioneer p4300 HU, and I have my fronts and rears running on the front channel and the rears set as sub on the HU which are run to 2 12s that I have built an enclosure for and put coils in it to keep the higher frequincies out. the thing sounds great and vibrates the hell out my car. the question I have is that there are 3 settings for the sub, 50,125,160 I believe. well anyway. when you set it to lets say 125, does it let all frequincies 125 and below to the speaker, all frequincies 125 and above or only 125. and I assume that the settings for higher frequincies will have the same rules as the lower as far as the pass filters go? I hope I made since with all of that. thanks
Shane
Old Jan 30, 2006 | 09:01 PM
RangerPilot's Avatar
RangerPilot
What is the thing near the label? X-over? Any of those would be insanely high for a sub, so I doubt it. If it is a crossover, high frequencies will destroy your subs quickly.
So is there a label near this setting thing you speak of?
Old Jan 30, 2006 | 11:05 PM
voodoosurfer
its built into the HU, you can tell it to use a frequincy of either 50,80 or 125 and then 0-+6 level. its built into the HU.
Old Jan 31, 2006 | 12:51 AM
IPACA9's Avatar
IPACA9
you don't need the coils if your radio or amp has crossovers. Coils steal power.
Old Jan 31, 2006 | 07:27 AM
voodoosurfer
Ok, I might pull those out and try that also, but what about the frequincies? if it is set to 50 then does it only send the 50 frq. or does it send all freq. up to 50 and then cut it off. so like if it is set at the 125 will it send the 50,80 and 125 or just the 125 freq.
Old Jan 31, 2006 | 09:58 AM
RangerPilot
I dunno...that's something new to me. Let's start simple, is it in some sort of menu or something? How do you access these choices and what not?
Old Jan 31, 2006 | 12:17 PM
voodoosurfer
its in a sub menu on the HU, you can set it to either front and rear channels or to front and sub, where the rear channels are now being driven by an internal amp in the HU which gives you cut off points of 50,80 and 125. I just didnt know if these are hard freq. or if they will play all frequincies up to that point. not a big deal I have it to where it sounds really good, I was just wondering. thanks
Old Jan 31, 2006 | 02:56 PM
RangerPilot
All I can figure are those are hertz cut offs of 50Hz, 80Hz, and 125Hz. Makes sense for a sub. 50 would be good with a 12" or 15", 8" and 10"s probably can't hit them really well. That's what I've decided. Make any noticable difference in the real low notes when you change it?
Old Jan 31, 2006 | 03:05 PM
voodoosurfer
ya, with it on 50 it is a real solid low, at 80 it is alot louder and messier sounding kind of a droning, and 125 I loose almost all of my bass, which I figure is due to my coil I have built into the speaker boxes, which I think cuts off at 80. I knew they were the hertz cut offs but when you have it at lets say 125Hz, would that also still send the 50Hz also? Im thinking it does the more that I thik about it.
Old Jan 31, 2006 | 05:11 PM
Beerstalker's Avatar
Beerstalker
It will cut off any frequency above that. For example 125 will pass 0-125Hz to the speakers, 50 will pass 0-50Hz to the speakers, etc.
Old Jan 31, 2006 | 09:57 PM
RangerPilot
Exactly. It's trying to reproduce a broader band of frequencies, that's why it sounds messier.
WB4IUY
Aug 20, 2016 07:59 PM
nagetech
Sep 9, 2015 09:00 AM
MeÐiCX
Jan 28, 2013 06:19 PM
ToysRUs
Apr 28, 2012 02:45 PM
Patatoe1
Sep 28, 2005 11:05 PM
