Computer troubles
Old Jan 30, 2006 | 04:06 PM
Nohaj1's Avatar
Nohaj1
Computer troubles
I have a toshiba laptop with windows XP and I have an external hardrive that I connect to it occasionally. My problem is that the external hardrive usually registers as an E: drive but now it has changed to an F: drive. This wouldnt be a problem but I have an Ipod and now Itunes cant find any of my music that is on the external drive. I could manually change everything within Itunes but that would take hours. How can I change the drive back to E: or what else can I do so that Itunes will find my music.
Thanks
Old Jan 30, 2006 | 04:34 PM
Mil1ion's Avatar
Mil1ion
Do you use the USB to connect them ?
If so, use a hub to the laptop USB port and see if that works.
I aasume there is a USB controller in your laptop
Old Jan 30, 2006 | 04:41 PM
ag-ford-4x4's Avatar
ag-ford-4x4
What have you done lately....like right after the last time it was correct? Windows OFTEN reassigns drive letters when something else takes precedence...like a flash drive. There is a setting in the properties for the drive where you can SET this letter assignment....when i get home, ill see what i can find for details.
Old Jan 30, 2006 | 05:40 PM
rangerxlt02's Avatar
rangerxlt02
Have both devices connected to the PC
Right click My Computer | Manage | Storage | Disk Management
There you can locate your devices and re-assign drive letters. Might have to assign first device to a different drive letter first, in order to get access to the E drive.
Should also remember those settings the next time you plug them in (should, not 100% sure though)
Good luck to ya
Old Jan 30, 2006 | 06:15 PM
jake00's Avatar
jake00
theres no option in itunes to just change the folder it looks for mp3's in?
Old Jan 30, 2006 | 07:35 PM
Nohaj1's Avatar
Nohaj1
Thanks for help guys I got the drive name changed. I appreciate it
as always
ddrumman2004
15
Dec 29, 2010 09:52 PM
sierraben
18
Mar 12, 2008 08:30 PM
Bargod
Aug 13, 2005 08:22 PM
CowboyBilly9Mile
Dec 17, 2003 10:54 PM
