Bronco II Ford Bronco II
86 2.9 Big Problem
Old Jan 29, 2006 | 11:45 PM
YJ94's Avatar
YJ94
86 2.9 Big Problem
I HAV AN 86 BRONCO ll 2.9 THAT WILL START AND RUN UNTIL IT WARMS UP TO OPERATING TEMP THAN THE IDIL WILL START TO GET ROUGH AND DIE AND WON'T START OR IT WILL START AND RUN SO BAD THAT YOU CAN HARDLY MOVE I CAN LET IT COOL START IT AND IT RUNS JUST FINE MAYBE FOR A WEEK OR SO THAN SAME THING AGAIN THIS PROBLEM IS INTERMITTED THANK FOR ANY HELP.
Old Jan 30, 2006 | 06:55 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 30, 2006 | 11:21 AM
mrshorty's Avatar
mrshorty
The best first step on these seems to be to pull codes from the EEC-IV computer. Ken's tech info post at the top of the forum has instructions.
Old Jan 30, 2006 | 11:25 AM
YJ94's Avatar
YJ94
Hey Thanks I Had Them Done And They Came Up Evp Sensor Below Min Volt,bp/map Sensor Out Of Range,tps/pedal Position Below Min Volts.
Old Jan 30, 2006 | 05:10 PM
mrshorty's Avatar
mrshorty
Now, which of those codes were KOEO codes (before separator pulse during KOEO test), which were KOER codes (if you performed the KOER test), and which were continuous memory (CM) codes (after separator pulse during KOEO test)? Which portions (if any) came back pass (11)?
SOP is to resolve the KOEO codes first, then resolve any KOER codes, then clear CM and see which codes come back and work on those.
Old Feb 1, 2006 | 12:51 PM
YJ94's Avatar
YJ94
Thanks For The Info,i Had The Codes Checked At Auto Parts Store A Don't Think The Guy Had Much Knowlage On It,however I Thought I May Check The Fuel System And Found That I Was'nt Get Any Fuel Output From The Fuel Pump In The Tank So I Replaced It And Screen So Far So Good The Front Pump Was Running So I Din't Sucspect It My Son Will Drive It For Awile And I GESS Will See If That Fixed It. Thanks Again
