Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Socket Set Organizer
Old Jan 29, 2006 | 05:59 PM
ag-ford-4x4's Avatar
ag-ford-4x4
Anyone know where i can get some kind of PORTABLE socket set organizer?
I havea fairly large craftsman socket set with 1/4, 3/8, 1/2" drive sockets...with metrics. It came in a big plastic black case with a slot for each of them. Now thats fine and good, but they dont fit snug in there and when you close the case and pick it up to move it, MOST of them end up strewn about inside, where i usually leave them until i reorganize them.
Does anyone make something that i can organize my sockets like the original one, except where they stay in place??
Old Jan 29, 2006 | 06:05 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
If you want to use the same case a TINY amount of expanding foam copuld be injected at a few points to make the case stiffer.
Old Jan 29, 2006 | 06:12 PM
ag-ford-4x4
thats a good idea to get me by. Ideally, the identical case with posts that would actually GRAB the sockets would be nice....
if i had a big enough garage and a permanent home, i would get a drawer organizer for sockets...those are everywhere.
Old Jan 29, 2006 | 06:26 PM
Fordteamone's Avatar
Fordteamone
socket holder
Craftsman makes socket holders that work good for me, some of the ones I got are locking and I lay them in my field tool box with no problem. I think the new blow cases that the tools come in are junk and have moved back to using a steel hand box.
Old Jan 30, 2006 | 12:23 PM
Mr.Ford 351W's Avatar
Mr.Ford 351W
Sear has a socket set oraganizer by Lisle brand, for Metric and SAE
Old Jan 30, 2006 | 09:04 PM
Phinxter's Avatar
Phinxter
I had that problem, I just put a thin piece of cardboard in the case. I have some socket rails and other organizer stuff that I like made by Ernst MFG Co. And they are inexpensive and really cool. Even Stacy David uses them. heres a link
http://www.ernstmfg.com/
Old Jan 31, 2006 | 12:29 AM
mason55's Avatar
mason55
Maybe a magnet strip would work ? I like socket rails best for road boxes though. They are cheap and efficiant way to hold sockets.
Mason
Old Jan 31, 2006 | 01:54 PM
Pony Power's Avatar
Pony Power
How about gluing a piece of 1/2" or thicker Polly foam sheet similar to what they use in gun cases. that would be a cheap fix and keep the stuff in place.
Old Jan 31, 2006 | 03:51 PM
plapczynski's Avatar
plapczynski
I have the Lisle one. In the past I used the metal clip rail, but after a while the socles wear out. The Lisle one is magnetic, so you can take the full set to the job area with you. Handy when you don't know the exact size or metric or SAE. I have mine arranged by drive and then have the deepwells on one side and the regular ones on the other side. I also looked at the hansen trays, which looked nicer but lost the functionality of taking all of them under the vehicle. I often end up sliding the tray around and pushing the tray out when I am done and the magnets hold all the sockets in place. It also holds them firmly in the chest. Mine are all orange, but I understand they make two colors for metric and SAE.
Old Jan 31, 2006 | 05:05 PM
ag-ford-4x4
maybe ill head to sears and check it out. The polyfoam thing may be best, then they can stay in their original box too.
Old Feb 1, 2006 | 10:10 AM
Zane M's Avatar
Zane M
I've used foam in the original plastic case with great results.
The other organizers mentioned are great, but I like the portability(and flat profile) the original case provides.
Old Feb 1, 2006 | 02:59 PM
balddave's Avatar
balddave
I use two of these for my sockets. love em.
http://www.matcotools.com/ProductImages/444.jpg
Old Feb 1, 2006 | 08:50 PM
508markm's Avatar
508markm
i use a rag
where the rag is hagin over just fold it in. the sockets wont move nice tight seal.
the rag doubles to clean your tool before you put them away!!
i like that polyfoam idea too!
Old Feb 1, 2006 | 09:49 PM
amish77's Avatar
amish77
I wouldn't use the rag, no offense 508. That's just because I like a coat of oil to help in rust prevention. I use the ones from sears. Their cheap, and they organize the sockets well. They're basically like the rail that there's a link to. If the clips wear out then you can buy new ones for a buck or two. My only complaint is with oily hands they can hold onto small sockets a little too well if you get my meaning. Other than that I love 'em.
Old Feb 2, 2006 | 07:26 AM
ag-ford-4x4
i think the rag or foam would be best for me. All of my sockets get a coat of oil just from use. I really like to have them all together in one place, compact, and portable.
