Sector shaft seal
Old Jan 29, 2006 | 03:28 PM
1994fordranger's Avatar
1994fordranger
Sector shaft seal
I Have a 1994 Frod Ranger 3.0 @wd manual trans. I am trying to replace the sector shaft seal (lower by pitman arm). I removed the snap ring Now I can't get the seal out. I tied starting the truck and turning the steering wheel with the pitman arm connected and disconnected. The seal wont budge. I read a couple posts the pressure should push it out but no luck. Please HELP!!!
Old Jan 29, 2006 | 05:14 PM
03XLT4x4 Flareside's Avatar
03XLT4x4 Flareside
If the pressure trick don't work, there is two ways of removing them. Either remove the sector shaft, then pry the seals out or you can drill two 1/8" holes on each side of the seal & screw in two long sheetmetal screws & pull out the seal with those. Just be carefull not to drill into the sector shaft or housing.
Old Jan 29, 2006 | 05:20 PM
buffalobob's Avatar
buffalobob
my experience with this problem is mixed...a small percentage of the time the leak will be fixed with a outer sector shaft seal replacement but Ive found the majority of the time the box needs to be replaced ....... the $20 spent on outer seals doesnt fix the leak. Just my $.02......
Old Jan 30, 2006 | 07:12 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome 1994fordranger to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 2, 2006 | 05:15 PM
1994fordranger
I tried drilling the first seal and burnt up 3 new bits and didn't even mark the seal. Or how do you remove the sector shaft? Can i do this with the box still in the truck?
blacktundra10
Dec 27, 2011 08:49 PM
dr1
Mar 22, 2008 03:03 PM
dvldog458
Aug 9, 2007 10:46 AM
turnrjr
Dec 27, 2006 07:43 AM
MIkeT150
Nov 30, 2003 01:36 PM
