Bronco II Ford Bronco II
Carbarator
Old Jan 29, 2006 | 02:09 AM
nosubfordiesel's Avatar
nosubfordiesel
Carbarator
Has anybody ever swithced from fuel injection to a carb? I have an 86 with thge 2.9L
Just Curious
Old Jan 29, 2006 | 10:23 AM
rwmorrisonjr's Avatar
rwmorrisonjr
You'd have to swap the intake manifold, fuel pump to a lower pressure one, and the computer for a non-FI one at the minimum. Why would you want to change to a carb, esp. if you have to pass emissions? It might be easier to do an engine swap/upgrade to stay within emissions specs and keep the cost lower.
Old Jan 29, 2006 | 02:23 PM
bronocIInoob's Avatar
bronocIInoob
Put it this way.. on a 350 v8 or somthing similar carbs are wonderful. But on a small 2.8 or 2.9 v6 or smaller, i think they suck, sence you get less power and less fuel mileage as well. In this case there isnt really an advantage of a carb at all. Look into switching your 1986 to a muiltport fuel injection system. I think the 86's had TBI (trottle body injection) which isnt that great at all.
Old Jan 29, 2006 | 02:36 PM
Bob Ayers's Avatar
Bob Ayers
Going from EFI to a carb is like going from radial tires to bias ply tires, or from color TV to black & white TV....WHY???
Old Jan 29, 2006 | 02:39 PM
bronocIInoob
he dose have a piont. Dont downgrade- up-grade!!!
Old Jan 29, 2006 | 05:57 PM
nosubfordiesel
I was just courious. I am not going to downgrade.
Old Jan 29, 2006 | 06:12 PM
bronocIInoob
oh sorry for the mis-understanding there. Im sure you could do it, but the heads may be differnt, idk. You should really consider swaping to muiltiport, that will show you hp gains
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
