Tilt front end
Old Jan 28, 2006 | 09:11 PM
BUCKFEVER's Avatar
BUCKFEVER
Tilt front end
I searched the old forums and found good advice from January of 2004. But the pictures from then would'nt open. Does anybody have any good pictures to post or could tell me were to look for them on tilt front ends.
thanks
Old Jan 28, 2006 | 09:56 PM
SuperSnake's Avatar
SuperSnake
Welcome to
Old Jan 28, 2006 | 10:10 PM
ferguson777's Avatar
ferguson777
There were some recent (like within the past 3 mths) discussions in the 48-60 forum. Not sure what year truck you're thinking of doing this to, but the discussion covered most points that need to be kept in mind... If you can't find it with a search in there, then start a new thread there and ask all your questions. Us 48-60 guys just love to talk...
Old Jan 28, 2006 | 11:26 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question as long as it is the one listed in your profile. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Jan 29, 2006 | 07:20 AM
BUCKFEVER's Avatar
BUCKFEVER
Smile
Thanks for the help & replies.
1978 f250
Old Jan 29, 2006 | 07:43 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check the user galleries. There are some "typical" flip front ends pictured. There have also been a number of threads here on the subject. The typical flip cuts thru the fender in front of the cowl down to the wheel opening.
Old Jan 29, 2006 | 12:22 PM
BUCKFEVER's Avatar
BUCKFEVER
thanks I"ll check it out
Old Jan 30, 2006 | 09:15 PM
Rocket Racing's Avatar
Rocket Racing
Check out www.usbody.com for some pics of how they hinge a fiberglass front end.
Old Jan 31, 2006 | 09:52 AM
KJKozak2's Avatar
KJKozak2
Are you looking to purchase a setup like this or build it yourself? I have pix of mine in my gallery 'TruckMods' that I did myself. It's a lot of work and there's a whole lot to consider when doing it, but it's worth it IMO.
Kevin K.
Old Jan 31, 2006 | 12:11 PM
Madmike33's Avatar
Madmike33
It looks great I've been thinking of building one myself, but have a lot of unanswered questions. All I really need is visuals. Would it be possible to post more specific pictures? for ex: tilt, rad support, how you got the bumper to clear framerails, what the whole assembly sits on at the firewall, what you used to hold down at the firewall, how you had everything hold together as one clip, rams? etc.
Any pictrues would solve much of this, and I would really appreciate it.
Thanx
Madmike33
Old Jan 31, 2006 | 01:11 PM
KJKozak2's Avatar
KJKozak2
I have lots of pix I took of the project but too many to post. If you send me an e-mail with your address, I can send them directly to you.
The basic concept for mine is that everything is mounted to the rad. support. The fender itself carries the weight of the hood and inner fenders. The hinge is just an angle and a plate bolted to the support that pivots on a pin on the frame. The bumper is bolted to the plate and tilts with the clip.
The radiator is bolted to the frame rails with angles, and I ran square tubes from the top back to the firewall for a little more support. They also give me a place to run wires and mount the windshield washer bottle.
The tricky part is that everything that was mounted to the inner fenders has to be relocated to the firewall.
When the hood closes, the inner fenders rest on their original brackets that are bolted to the firewall. I cut a slot in the bracket and put a bolt through the inner fender to sild einto the slot. I used latches from a corolla hatchback and fitted them inside the brackets to catch the bolt.
These are just the basics and the pix should clear up most of it.
Hope this helps.
Kevin K.
Old Jan 31, 2006 | 02:25 PM
Madmike33's Avatar
Madmike33
Hope this helps.
Kevin K.
Thanx Kevin, I'll send you a PM with my email adress, cause I know FTE won't let me post it on the boards
Madmike33
Old Jan 31, 2006 | 05:06 PM
Torque1st's Avatar
Torque1st
Posting Legend
Just send an email, it works better.
One thing you might want to consider is rubber mounting many of the components. It takes more fab time but is well worth the effort. Standard shackle and spring bushings as well as shock bushings can be used to keep parts easy to find. It will make the vehicle less rattle prone and much more pleasant to drive.
Old Jan 31, 2006 | 06:23 PM
BUCKFEVER's Avatar
BUCKFEVER
thanks for the replies
i have a 78 f250 that i only run about 1000 miles a year and take to a couple of shows a year show. i want to tilt it to make different.
buckfever
Old Jan 31, 2006 | 09:57 PM
KJKozak2's Avatar
KJKozak2
Torque's right. Especially for the radiator. My initial setup was hard mounted to the frame. I've since put rubber bushings between the angle and frame and rubber washers on the bolt.
Buckfever, you'll have to send me an e-mail and not a private message. E-mail addresses get deleted from private messages for security purposes. Drop me a line and I'll be happy to send you all the pix I have. Just remember mine is nowhere near a show truck. My mods are functional but not pretty.
Kevin K.
