rebuild 361
rebuild
i will get the barrel and block test be four i do any think i have two of this motors one has thin barrels at stock bore 3.78,MD and the one i think is the one to use has thick barrels at a stock bore 3.78 HD to very diffent block but same bore s rember these are truck motor s and the drill bit test is a good 1st step to do , two diffent drills size on each barrel test
ps thank,s 4 the help
rebuild 361
im still waiting for my block to come back from the shop he is testing it next week i think and then i will pick what way to go out to if i can get 4.05 i will go with that bore like you guy think 4.05 sound nices i pick up a 4barrel intake manifold from a mate for free (wow they weight hepps )casting number are -D5TE-9425-TA is a match to c6me-a block ?
rebuild 361
Hi i was think of a stock 361 uping the compess a bit cleaning up the heads ihave a 4bl manifold , any idea ? rusty i have the rebuilder looking for silvolite
pistons your told me about 3144d,3142d i found them on the net couldn,t
find 3176d,1136 thanks again guys let me no if you guys ever come over to australia ok im near canberra small farm i breed mini gallaways cows , and the mustang 2054 skidsteer .The truck pass thr rego again this year with out touching or spending any cash on it The motor rebuilder is getting married
will be gone for three weeks he only build raceing engine so im very lucky to get him to build it for me. He gets raceing motor from all over australia to build he,s call pro_engines , i have to go and dig a hole for a dead cow now ill check in later
So, .213" was the minimum wall thickness with 3.875" cylinder bores? Let me do some math here:
4.050" - 3.875" = .175" difference.
.175" / 2 = .0875" off the cylinder wall on each side to get to 4.050"
So, .213" - .0875" = .1255" minimum cylinder wall thickness after boring to 4.050".
You do not have 428 cylinder wall cores, or even standard 390 wall cores. Looks like the 330 casting, or at least yours, uses smaller cylinder wall cores.
I think it's best to leave at least .150" wall thickness after boring, so I think you're kind of stuck.
I think your best bet would be to go find a mid 1970's 360 truck block (like F100 through F250). That would swap right in and give you the bore size you're looking for. Look for one with the mirror image "105" where the "352" would be on a normal FE block.
#28
#30
So .310" was the minimum?
In that case:
So, .310" - .0875" = .2225" minimum cylinder wall thickness after boring to 4.050".
Now, it's looking like that block would be plenty safe to bore to 4.050".
Just out of curiosity:
4.130" - 3.875" = .255" difference.
.255" / 2 = .1275" off the cylinder wall on each side to get to 4.050"
So, .310" - .1275" = .1825" minimum cylinder wall thickness after boring to 4.130".
I think it would even be safe at 4.130". Of course, there's no pistons for that and a 3.5" stroke crank.
Were those the results for one cylinder, or did you get all eight tested?
In that case:
