rebuild 361
rebuild 361
Hi all just pull down my 330 ft block for rebuild . I need help with parts like which pistons ( its stock ) a nices cam do i get the heads dunn , how big do i bore ? im think 361 .This in a bigger f so i want all the torque i can get im in aussie and its hard to get parts so i will be buy in the usa
From what I have read here you pretty much treat it like any other FE block except you need to seek out an adapter for the distributor. I've never touched one of these things, but I have come to understand that the crank/rod/piston stuff is pretty much the same. Look at the FAQs. I seem to remember that there is some discussion about it.
if he is building a FT then the dizzy spacer is not needed. the crank.rods and pistons in a FT are different than a FE. the pistons are low low comp. the rods are long and the cranks are forged steel.
rebuild
i would like to stay with the 361 as i have to motors , where can i get piston in the usa or a rebuild kit ?which brand piston are good things like that i need
to no and where and only ft no fe and any inprovement to make it better on fuel, power and torque thanks guy i no you guys no heaps about the might
ford v8 s
ford v8 s
rebuild
Hi guys ( thank you all ) its a stock bore now 3.78 but this block can be bore a fair bit ( C6ME-A) i did the drill bit test 13/64 fits neat , if i bore it out to 4.100 x 3.55 = 370 cui keeping the compression low still around the 8, to one so it won,t get to hot , ill get the port tidyed up to, cam ? will this work ? i tri to do my home work on this first so how am i going so far with this ?
