Setting alarm without remote door opener
Old Jan 27, 2006 | 09:49 PM
fuelmover's Avatar
fuelmover
Does anyone know if there is a way to set the alarm using the key or the keypad? I lost my remote opener and don't seem to be able to set the alarm using the key or keypad. I checked the manual and it only talks about setting the alarm with the remote opener.
Old Jan 27, 2006 | 10:19 PM
okst1's Avatar
okst1
On the keypad, hold the two far right buttons down at the same time.
Old Jan 28, 2006 | 07:44 AM
IPACA9's Avatar
IPACA9
Or hit lock on the door switch just before you close the door.
Old Jan 28, 2006 | 10:22 AM
fuelmover's Avatar
fuelmover
I have tried both those methods but the horn doesn't honk indicating that the alarm has been set.
Old Jan 28, 2006 | 11:02 AM
crewsr's Avatar
crewsr
From what I remember I didn't think the horn honk indicated the alarm is set. It was telling you that the vehicle systems are secure i.e. no headlights on all doors closed tight etc. I don't have a security alarm that I'm aware of. If I'm wrong someone help set me straight...
Old Jan 28, 2006 | 12:00 PM
IPACA9's Avatar
IPACA9
Ummm... I'm thinking the excursuin doesn't have factory security. I know my 01 doesn't have it and I can't remember if I've ever had to shut it down when adding a remote start.
Maybe some other Excursion owners could verify this for me. The way I test it is:
1. Sit in vehicle with door open.
2. Hit lock on the door and then close door.
3. AFTER dome light goes out count 30 seconds.
4. Pull your door handle to open door.
5. The horn should start honking if you have an alarm.
6. Shut alarm off with either your key fob remote, code on the door, or use your key in the drivers door and turn it to unlock.
Let me know what you find out.
Old Jan 28, 2006 | 12:45 PM
fuelmover's Avatar
fuelmover
Thanks for your help. I think it was a misunderstanding on my part. All other vehicles I had, the chirp or horn indicated that the alarm had been set. I guess in this case, it just indicates that all the doors are locked.
Old Jan 28, 2006 | 05:02 PM
okst1's Avatar
okst1
The horn chirp only works after you have hit the button on the fob twice. If you hit it once-no horn.
bkuuz1
6.7L Power Stroke Diesel
Sep 27, 2016 09:37 PM
pmyers
Feb 24, 2016 06:38 PM
cardboard
2009 - 2014 F150
Mar 13, 2015 12:26 PM
chowder
2004 - 2008 F150
23
Nov 25, 2005 08:03 AM
Chris_in_Texas
Jul 1, 2005 10:59 AM
