Sponsored by: Real Truck
Defrost only
Old Jan 27, 2006 | 04:00 PM
JMACC's Avatar
JMACC
Defrost only
I jumped into the truck a short while ago and went to turn the vent on and no vent?(heat) it was just working but the only thing I do get is defrost. The floor and the vent floor does not work only the defrost even when I switch the selector to the other choices it stays on defrost? Has any one else had aproblem like this? and if so what was the problem?
Old Jan 27, 2006 | 04:12 PM
Beerstalker's Avatar
Beerstalker
I'm pretty sure I remember reading about this on here not too long ago. I believe they said it is a vacuum leak in the system that controls the door. If there is a vacuum leak it goes to the default setting of defrost so you can always clear your windows.
Here is one thread I just found.
https://www.ford-trucks.com/forums/s...d.php?t=378133
Just click on search near the top right of your screen and search for defrost. You will come up with a bunch of threads on this.
Old Jan 27, 2006 | 09:10 PM
tgarst's Avatar
tgarst
There is a vacuum connection under the dash on the passenger side just above where the carpet stops. This connection can be knocked loose with your foot. Mine was loose and I had no max air. I have a 99 SD
Just a thought
Tim
