Sponsored by: Real Truck
Transmission Service
Old Jan 27, 2006 | 03:27 PM
SCHRADE's Avatar
SCHRADE
My new to me 2000 F250 4x4 has not had any transmission problems but I dont know if the trans has ever been serviced. Now has 70K on it.
I have a good trans shop near me. What should I have them do? Filter change? Trans flush? Transfer case? Front and rear differentials?
Also I have the 4R100 trans so isnt there some kind of special fluid that I need to use?
Thanks a lot for your help
Old Jan 27, 2006 | 03:44 PM
schmidt64's Avatar
schmidt64
Should just use mercon and i would just do the transmission flush, leave the filter, its more just a screen and doesn't really require replacement. Front and rear diffs should be ok till over 100K assuming they've never been submerged in water
Old Jan 27, 2006 | 03:45 PM
SCHRADE's Avatar
SCHRADE
Schmidt
What do you think about the transfer case?
Old Jan 27, 2006 | 03:48 PM
Big Cheese Stick's Avatar
Big Cheese Stick
Were it me... I'd go with synthetic fluids in both. Do the differentials as well.
Old Jan 27, 2006 | 04:22 PM
wlihntr's Avatar
wlihntr
i agree. make sure they use mercon, not mercon V or a mercon/mercon V fluid. i would also suggest going with a synthetic fluid, mobil 1 is good. i would do the x-fer case as well and use synthetic it that too. if you are any kind of wrench you can do the x-fer case your self, it takes 2 quarts of mercon (same as the trans)
Old Jan 27, 2006 | 04:23 PM
SCHRADE's Avatar
SCHRADE
So is Mercon a synthetic?
Old Jan 27, 2006 | 04:25 PM
schmidt64's Avatar
schmidt64
what about the generic dexron III/mercon ATF?
Old Jan 27, 2006 | 04:30 PM
Big Cheese Stick
No telling if the previous owner got water in the diff.s. Play it safe man! If you change the diff. fluid yourself its SUPER cheap insurance!
Old Jan 27, 2006 | 04:48 PM
wlihntr's Avatar
wlihntr
mobil 1 makes a full syn. mercon/dextron III (mercon and dextron III are the same thing) but just because its mercon does not mean its syn.
Old Jan 27, 2006 | 05:58 PM
asdfg's Avatar
asdfg
I believe you would use Mercon "SP" if you wanted synthetic, My 05 torqeshift calls for this and I could only find it at the dealer.Flush,new external filter and 15 qt "SP" for $99.99 from the dealer was a great deal.
Old Jan 27, 2006 | 09:32 PM
rwilimo's Avatar
rwilimo
Mercon sp is only for the torqueshift, do not use it in a 4r100.
Old Jan 28, 2006 | 12:09 AM
Big George 150's Avatar
Big George 150
I would get it all changed. The trans flush, the differentials and the transfer case. If you don't know what was done to the truck or what the truck was used for before you bought bought it I would have it changed for peace of mind. I keep all the reciepts on all the work done so when I trade the truck in they know what has been done.
Old Jan 31, 2006 | 01:34 PM
SCHRADE's Avatar
SCHRADE
Fluid too many choices
Ok, I am going to have the trans flushed, and fluid changed, and the transfer case changed. I am going to leave the filter in and leave the differentials alone.
I have the 4r100 so I use the Mercon III fluid? Is this available at China Mart?
Old Jan 31, 2006 | 01:43 PM
schmidt64's Avatar
schmidt64
you just need regular dexron III/Mercon ATF, and yes, they sell it
Old Jan 31, 2006 | 09:00 PM
muffett's Avatar
muffett
I'd do everything, particularly if it was a used truck. In the end, it's cheap insurance. It payed off for me. My first SD was a used 99 SD CC V10. I did all the fluids when I bought it, and then complete driveline servicing every 2 years or about 40 kmiles. When I had trans case "noises", receipts for that regular maintenance shut the warrantee adjuster up and I got the new trans case without question.
Greg
