frame rail fuel pump
Old Jan 27, 2006 | 01:36 PM
earl964's Avatar
earl964
Exclamation frame rail fuel pump
Can anyone tell me why the frame rail fuel pump would still hum after you shut off the motor and remove the key ? The only way to shut it off is to disconnect the battery . The truck is an 88 F250 351 motor , any help ?, any suggestions ?
Old Jan 27, 2006 | 02:38 PM
subford's Avatar
subford
Sounds like the Fuel Pump Relay Contacts are welded together. Replace Relay.
Old Jan 27, 2006 | 03:30 PM
earl964's Avatar
earl964
thank you were would I find the relay ?
Old Jan 27, 2006 | 05:23 PM
Popa Tim's Avatar
Popa Tim
I'm not sure on an 88, look under the hood for a relay & fuse center.
Old Jan 27, 2006 | 05:47 PM
EPNCSU2006's Avatar
EPNCSU2006
The fuel pump relay is the green relay mounted to the back side of the air filter box.
Old Jan 27, 2006 | 07:02 PM
earl964's Avatar
earl964
thank you guys for the quick response the weather is going to be nice tomorrow I will try to figure that out, once again thank you
bobcf
Aug 17, 2015 08:56 PM
smokenchoken
Jul 28, 2014 07:59 PM
1964 hammer
Jul 1, 2013 11:14 PM
Leland337
26
Mar 20, 2013 12:22 AM
schlepprock250
15
Nov 30, 2012 07:54 AM
