help
Old Jan 27, 2006 | 09:05 AM
atlautomotive's Avatar
atlautomotive
Question help
hi, i have a 1993 f150 with the 302 and dual gas tanks my problem is i get 14 mpg out of the frount tank and 8mpg out of the back tank i have keep up with the mpg since i got the truck 3 weeks ago
thanks dwayne
2wd
19 axle code
191000miles 25000 on new motor
all stock
Old Jan 27, 2006 | 09:18 AM
subford's Avatar
subford
You have bad check valves in the tanks, it’s called a cross-flow problem. You need to do the Recall Fix by putting check valves in the fuel lines. Then more than likely you will get 11 MPG out of each tank.
Welcome to the fourm
Next time name your thread something that other users can search with if they have the same problem, such as "cross-flow"
Bill K
