Modular V10 (6.8l)
v-10 heads
Old Jan 27, 2006 | 07:51 AM
syd724's Avatar
syd724
v-10 heads
Did ford correct the plug blow out problem on the 2006 model year.
Old Jan 27, 2006 | 08:03 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
If you get a minute check out the link here, it will help you to navigate around and understand this site.
https://www.ford-trucks.com/forums/s...88#post3272088
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
Old Jan 27, 2006 | 09:21 AM
G Lube's Avatar
G Lube
As far as I am aware, the blow out problem was fixed in the 2001 or 2002 year SDs. I know after 2002, no more spark plugs were blowing out so yes, the problem has been solved for the 2006 model year.
Gary
Old Jan 27, 2006 | 08:29 PM
wulfeye's Avatar
wulfeye
i neglected to search, but what is this blow out your speaking of, well what causes it ?
Old Jan 27, 2006 | 09:07 PM
BareBones's Avatar
BareBones
The old heads only had 3 or 4 threads for the spark plugs so there were instances where the plugs vibrated loose and blew out. But this was fixed with the 10? threads in the PI heads when they were introduced around 2002 as G Lube mentioned.
Old Jan 27, 2006 | 09:09 PM
BareBones's Avatar
BareBones
Then of course in 2005 the V10 heads were completely re-designed for the 3-valve configuration, so the blow-out problem should be history.
Old Jan 30, 2006 | 02:25 PM
PurerockRacing's Avatar
PurerockRacing
so 2001 heads would have the minimal threads? How to you tell ifyou have the PI heads? Is there a casting number to look for?? Mine only has 49k miles, but I am still wondering if there might be a potential problem to watch out for on my truck
Old Jan 31, 2006 | 12:06 PM
krewat's Avatar
krewat
My 2001, manufactured in 10/2000 has the PI heads.
Old Jan 31, 2006 | 12:54 PM
PurerockRacing
Krewat
have you physically looked to see how many threads you have in your heads? and how do you know you have the PI heads? Is there a part number or casting number to look for?
Old Jan 31, 2006 | 01:10 PM
krewat's Avatar
krewat
Originally Posted by PurerockRacing
Krewat
It has "PI" cast into the side of it. I'm pretty sure you can look through the wheel well at the rear outboard side of the head and it says PI in big letters.
When I recently did my plugs, I checked the holes with an inspection mirror and I can say with CERTAINTY that there were many MORE threads than 3-4.
More like 7-8 or maybe even 9-10.
And yes, the motor was never changed, and never opened, and the sticker on the valve cover says 10/2000 manufacture date.
I've heard plenty on here about "after such-and-such date, the heads were changed" or "PI heads were fixed", etc. etc. I have YET TO SEE any conclusive proof of that, and as an example, my 10/2000 motor has the PI heads and lots of spark plug threads, unilke the "2002" mentioned above.
Old Jan 31, 2006 | 02:06 PM
PurerockRacing
thanks!! I'll look tonite.
Old Jan 31, 2006 | 03:05 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
The PI heads started in the 2000 model year when the HP was upgraded to 310
Denny
Old Jan 31, 2006 | 03:08 PM
PurerockRacing
sure seems like I've seen some posts on here from people with post 2000 models and blown out plugs, maybe I'm wrong (wouldn't be the first time).
Old Jan 31, 2006 | 03:36 PM
rvpuller's Avatar
rvpuller
Yes there has been but most are from the plugs not being changed properly and that can an does happen with any aluminum head.
Denny
Old Feb 1, 2006 | 08:24 AM
PurerockRacing
I looked last nite with a flash light... sure enough, my castings say 6.8L PI. Thanks for letting me know how to find this.
