Sponsored by: Auxito
Ford lug stud size question...
Old Jan 27, 2006 | 02:29 AM
wgotthardt's Avatar
wgotthardt
(Perhaps someone here knows, as I did not get a reply on the Explorer board...thanks.)
Did Explorers/Rangers also switch from 12mm studs to 14mm studs at some point? If so, in what model year?
Thanks.
Cheers, Wm.<!-- / message --><!-- no sigs except when logged in -->
Old Jan 27, 2006 | 05:41 PM
steve(ill)'s Avatar
steve(ill)
not that i know of. you do know the explorer has a 4.5 inch bolt pattern and the F150 has a 135 mm pattern? the rims are not interchangable if that is the next question.
