Outside Air Temperature...
Old 01-26-2006, 10:53 PM
Patatoe1's Avatar
Patatoe1
Patatoe1 is offline
The air temperature is way off. Today it was saying that it was 82 outside, but it really was only in the 40's. It has been like this for a couple weeks now.
Has anyone had this problem, or know if there is a way to fix it?
Old 01-26-2006, 11:01 PM
dilas's Avatar
dilas
dilas is offline
Not sure about temperature, but with compass, you would need to calibrate it based on your current zone. There's a simple procedure on compass calibrating in the owner manual.
Old 01-26-2006, 11:16 PM
Patatoe1's Avatar
Patatoe1
Patatoe1 is offline
Sorry if I wasn't clear. The compass is fine. The Temp is what is way off.
Old 01-27-2006, 08:25 PM
AzPete's Avatar
AzPete
AzPete is offline
CHeck to see if the temp. sensor has been moved. I think it is behind the grill. If it has gotten close to the radiator, it might give false readings.
Old 01-27-2006, 10:16 PM
StngStr's Avatar
StngStr
StngStr is offline
maybe reading warm temps from your engine?
Old 01-29-2006, 03:17 AM
riverratmike's Avatar
riverratmike
riverratmike is offline
where is the temp probe supposed to be mounted? I just got a temp/compass mirror and I'm getting higher temp readings when I'm stopped/idling.
Old 01-30-2006, 08:41 AM
flyfish03's Avatar
flyfish03
flyfish03 is offline
I'm having the same trouble as Patatoe1. Will this have any to do with the inside temp I have set?
1L243
06-18-2011 07:21 PM
BlackstarF250
1999 to 2016 Super Duty
04-02-2011 03:47 PM
98explorerltd
01-14-2009 04:31 PM
JackDaniel
Electrical Systems/Wiring
01-06-2008 07:41 AM
beemr
11-20-2005 09:23 AM
Quick Reply: Outside Air Temperature...
