E4OD swap for a 5 speed
Old Jan 26, 2006 | 10:12 PM
Nate27's Avatar
Nate27
I got a 94 250 4X4 7.3L IDI with and E4OD transmission I have been wanting to put a 5 speed for a while now and I was wondering how difficult it is going to be? I dont know if my transfer case will fit, I will need a hydraulic clutch, a longer drive shaft, cut a hole in my floor board? Is there anything else that I will need to do that Im just not thinking about? And how difficult is swapping the two different transmissions. Thanks for all the help
Old Jan 27, 2006 | 10:56 AM
trooperkelly's Avatar
trooperkelly
I have the same truck and thought of doing the same when my tranny died.
There was a thread on the basic requirments a while back but don't remember much . As for me i decided to fix the auto and down the road buy
one with a 5 speed.
Old Jan 27, 2006 | 08:00 PM
Dave Sponaugle's Avatar
Dave Sponaugle
You will have a lot of work inside the truck.
Clutch pedal, hole in the floor for the shifter, column shifter removed, park/neutral interlock turned into clutch interlock, transfer case will fit the ZF5.
As far as driveshafts, they may be different.
johnguc
Sep 6, 2011 03:29 PM
johnguc
Sep 6, 2011 11:32 AM
hotrod33
Jan 18, 2004 10:43 PM
87fordf250tvs
Feb 24, 2001 12:19 PM
