Took my '67 out this afternoon to test things out. Discovered a few things. Need to fix front driveshaft angle situation. Think I will have to do the gay thing and put a body lift on my truck so I can level out my engine. Right now it is angled a lil bit cuz the tranny/tcase won't clear the 2wd floor-pan. Once the engine is sitting level I should be able to run a hi-pinion front and be good on my angles. Second thing I discoverd, need to weld my rear spider gears, cuz I wouldn't have been stuck if they were welded. Dropped my front driver side tire thru some deep snow and there I sat, front diff was almost burried and rear passneger side tire spun and front drivers side spun.
OH ya, was only a few miles from home. No stock vehicle would have made it to where I was to pull me out. Brother was sure to bring his digital camera along to get pics of the ordeal! LOL
shoot!! that ain't stuck, stuck is when the mud is commin in through the winders!!!
thats just takin a lil nap.
We got a yota stuck so bad the passenger side window was the only way out. So my chubby *** got to crawl out and walk back to the house while he wtch the vehical.
Think I will have to do the gay thing and put a body lift on my truck so I can level out my engine. Stuck
Nothing wrong with body lifting for a reason like that. I think Monsterbaby even has a slight bodylift on his, which he used as a crossmember to tie the frame together with. Making room for stuff is understandable, I can understand doing a bodylift on a ranger to stuff a 351 or 460 into em.
It's when you do it cause you're cheap that its ghey. It's even ok to do a body lift once you've done 6" of suspension lift. At that point just raising the body keeps your COG lower, and your components are still tucked up away from obstacles nicely. At least, that's how I see it.
i would go with as little of a body lift as possible, i ran a 1.5" at one time, i went aorund and collected leftover pucks from people doing 3" body lifts and once i got enough...cut them in half and bought bolts...it was hardly noticable, but gave alot of extra clearance
Discovered a few things. Need to fix front driveshaft angle situation. Right now it is angled a lil bit cuz the tranny/tcase won't clear the 2wd floor-pan.
thats what they made BFH's for. get under there and git to whompin on them floor boards till it fits proper.
