Offroad & 4x4
First Stuck
Old Jan 26, 2006 | 09:45 PM
ramboss429's Avatar
ramboss429
First Stuck
Took my '67 out this afternoon to test things out. Discovered a few things. Need to fix front driveshaft angle situation. Think I will have to do the gay thing and put a body lift on my truck so I can level out my engine. Right now it is angled a lil bit cuz the tranny/tcase won't clear the 2wd floor-pan. Once the engine is sitting level I should be able to run a hi-pinion front and be good on my angles. Second thing I discoverd, need to weld my rear spider gears, cuz I wouldn't have been stuck if they were welded. Dropped my front driver side tire thru some deep snow and there I sat, front diff was almost burried and rear passneger side tire spun and front drivers side spun.
So for your viewing pleasure here is my stuck.
Stuck
Old Jan 26, 2006 | 10:38 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
at least you have a tractor pulling you out, and not a chebbie or a heep..
Old Jan 26, 2006 | 11:10 PM
ramboss429's Avatar
ramboss429
OH ya, was only a few miles from home. No stock vehicle would have made it to where I was to pull me out. Brother was sure to bring his digital camera along to get pics of the ordeal! LOL
Old Jan 27, 2006 | 12:57 AM
Mr.G's Avatar
Mr.G
Too bad it was a case pullin ya out....
Old Jan 27, 2006 | 01:09 AM
76fordtruck's Avatar
76fordtruck
thats a pretty good stuck tho bro... that was some deeps snow... good job
Old Jan 27, 2006 | 02:19 AM
Russ T. Trombone's Avatar
Russ T. Trombone
Wwwwwwwuuuuuuuuuusssssssssssssssssyyyyyyyyyyyyyyyy yyyyyy
Ah hell, at least your taking her out and working her!
Old Jan 27, 2006 | 09:56 AM
tjc transport's Avatar
tjc transport
i ain't rite
shoot!! that ain't stuck, stuck is when the mud is commin in through the winders!!!
thats just takin a lil nap.
Old Jan 27, 2006 | 10:55 AM
78250crewcab4x4's Avatar
78250crewcab4x4
got my samurai stuck yesterday, I uh, had to test out the carburator rebuild, it ran great but the tires are still the limiting factor no pics though.
Old Jan 27, 2006 | 11:12 AM
s8whiskey's Avatar
s8whiskey
We got a yota stuck so bad the passenger side window was the only way out. So my chubby *** got to crawl out and walk back to the house while he wtch the vehical.
Old Jan 27, 2006 | 11:13 AM
Flareside94's Avatar
Flareside94
Stuck
Nothing wrong with body lifting for a reason like that. I think Monsterbaby even has a slight bodylift on his, which he used as a crossmember to tie the frame together with. Making room for stuff is understandable, I can understand doing a bodylift on a ranger to stuff a 351 or 460 into em.
It's when you do it cause you're cheap that its ghey. It's even ok to do a body lift once you've done 6" of suspension lift. At that point just raising the body keeps your COG lower, and your components are still tucked up away from obstacles nicely. At least, that's how I see it.
Old Jan 27, 2006 | 11:32 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
i would go with as little of a body lift as possible, i ran a 1.5" at one time, i went aorund and collected leftover pucks from people doing 3" body lifts and once i got enough...cut them in half and bought bolts...it was hardly noticable, but gave alot of extra clearance
Old Jan 27, 2006 | 05:49 PM
tjc transport
i ain't rite
Discovered a few things. Need to fix front driveshaft angle situation. Right now it is angled a lil bit cuz the tranny/tcase won't clear the 2wd floor-pan.
thats what they made BFH's for. get under there and git to whompin on them floor boards till it fits proper.
Old Jan 27, 2006 | 06:35 PM
brokebronco's Avatar
brokebronco
My brother and I got stuck in the experimental cornfield at the University of Maine like that one cold winter night.
Happened after a frat party, go figure.
Chris
Old Jan 27, 2006 | 06:58 PM
proeliator's Avatar
proeliator
Ummmmmm, okay dude, whatever floats your boat.
Old Jan 28, 2006 | 12:12 AM
chrono4's Avatar
chrono4
whos thinking in the gutter tonight pro?
