A daring move for a Ranger?
Old Jan 26, 2006 | 06:58 PM
pintopower8's Avatar
pintopower8
I have a 97' Ranger 4x4 supercab XLT 4.0 5-spd with a class 3 hitch. The company i work for has a 3500lb bri-mar tri axle dump trailer. i was thinking about bringing it home with me some day to do some needed welding. You think the Ranger can take it? I think it has the 3.73 axle. I would be sure to use a good stopping distance and go through the gears for engine braking. Its only a few miles. And of course no overdrive.
Old Jan 26, 2006 | 08:05 PM
79_250RangerLariat's Avatar
79_250RangerLariat
as long as the trailer is empty I'd go for it. My cousin has a 94, i belive, ex-cab, 5 speed v-6, 4x4. He's pulled ALOT more than it every should have, 4-lo to pull hills. I'm surprised it hasn't bent in half yet hauling scrap. Just rolled over 300k too
Old Jan 27, 2006 | 06:40 AM
jowilker's Avatar
jowilker
Pinto, I suspect that you could hook it up, start off and hardly know that it was behind you.
You shouldn't have a problem doing it. IMHO
John
Old Jan 27, 2006 | 06:53 AM
The SnoMan's Avatar
The SnoMan
John
Not likey. He might get by but he will know it is back there and will really feel it to starting out on the clutch. If it was a automatic, it would be a bit easier on it. Your biggest danger here is the clutch, go easy on it towing that trailer.
Old Jan 27, 2006 | 12:22 PM
mrc59's Avatar
mrc59
The rated tow capacity for a '97 that I know about is 2300#. Even empty, you're over. Question isn't can you, that truck will pull the trailer. The question is should you. That's your call!
Old Jan 27, 2006 | 02:22 PM
Kenworth's Avatar
Kenworth
Just make sure you have a brake controller to operate the trailers brakes there is no way the trucks brakes will stop the truck and trailer. As for pulling it your only doing it once so I don't see a problem its not like you will be pulling it every day.
Like Snoman says watch your clutch you could roast it once you smell burning clutch the damage has been done.
Why don't you use a company truck to pull the trailer instead of wrecking your own truck.
Old Jan 27, 2006 | 04:40 PM
79_250RangerLariat
I don't know if I'd really worry about the clutch much. As long as you know how to drive, and do it without abusing the vehicle it shouldn't be a problem.
I've gained some respect for those little rangers. My cousin hauls scrap on the side, took a load of old boilers out of here for me. Had over 4800lbs on his home built trailer, no brakes (probably around 1000lbs). Didn't smoke his clutch, but needed 4lo on the steep hill. And with any vehicle, over weight or not, extra care should be taken when pulling a trailer.
I wouldn't belive it, or figure it was just luck and good for only one or two times, but he's continually hauling upwards of 2500lbs in the back of his truck
Old Jan 27, 2006 | 05:51 PM
The SnoMan's Avatar
The SnoMan
I would because even on level ground it is going to have to work a lot harder and throw in a grade and you could easily toast it.
Old Jan 28, 2006 | 06:33 AM
jowilker's Avatar
jowilker
I would hook up a 25,000 pound trailer behind my half ton if I needed to move it a short distance, once.
You just have to drive like you have 25,000lbs behind you. He is not talking about taking a trip with it.
John
Old Jan 28, 2006 | 07:44 AM
The SnoMan's Avatar
The SnoMan
John
I understand that but the load weight as much or more as the truck and he has a stick with a relatively weak clutch and tall gears. If it was a automatic it would be a lot easier.
Old Jan 28, 2006 | 07:42 PM
pintopower8
automatics have weak torque converters too. I watched one of them blow up already
Old Jan 29, 2006 | 05:59 AM
The SnoMan's Avatar
The SnoMan
Nothing weak about stock torque converters on stock engines. The only ones I have seen fail have been for using a much bigger engine than the converter was designed for and the fluid super heats in converter and boils and bearing in it fail. A stock converter on a stock engine will no blow up unless it is defective (bad weld) and you will over heat the tranny before the converter fails in a stock setup.
Old Jan 29, 2006 | 09:20 AM
79_250RangerLariat
Tall gears or not, if you can't start in 1st gear without over reving and slipping the clutch you've got major problems. The biggest of which is learning to drive a standard. You've got to remeber it's a rolling weight, not a dead drag.
If one person can push a 3,000 lbs car in neutral across a flat area (ex in a garage), I'd surely hope a stock clutch could pull a 3500 lbs weight without smoking.
Old Jan 29, 2006 | 01:19 PM
rebocardo's Avatar
rebocardo
I had a 1997 4.0 5 speed 4x4, I do not think the weight is any problem at all. The problem will stopping and the width and length of a 3 axle trailer! If the trailer has brakes, I would say go for it. If not, I would think twice if this is an 8 foot wide x 24 foot trailer.
Old Jan 29, 2006 | 04:53 PM
f350xlt460's Avatar
f350xlt460
3500lbs for a TRI axle brimar dump? seems too little for that trailer. My tandem axle PJ dump weights over 4k empty. For a short distance it should be ok, but youll need a brake controler for sure... be careful...
