HERE ARE SOME ODOMETER DTC code definitions
Old Jan 26, 2006 | 01:08 PM
clouden's Avatar
clouden
(dont know how acurate these are, but I found them through a search, appearently they are the only codes a odometer test can display!!)
Self ..........DTC Description
Diagnostic
Mode
Displayed
DTC
9202.......... B1202 Fuel pump module circuit open
9204 .......... B1204 Fuel pump module short to ground
9342 .......... B1342 PCM is defective
9317 ..........B1317 Battery voltage high (greater than 16V)
9318 ..........B1318 Battery voltage low (less than 10V)
9359 ..........B1359 Ignition Run/ACC circuit failure
A143 ..........B2143 NVM memory failure
A477 ..........B2477 Module configuration failure
D041 ..........U1041 Invalid data for vehicle speed
D027 ..........U1027 Invalid data for engine RPM
D073 ..........U1073 Invalid data for engine coolant
D262 ..........U1262 Missing speed, tacho, engine temp, or odometer count
D123 ..........U1123 Invalid data for odometer
Old Jan 26, 2006 | 03:27 PM
onesr's Avatar
onesr
How do you get your odometer into dia. mode, is there a fuse or something or do you have to have the more complex style of odometer.
Old Jan 26, 2006 | 06:41 PM
Air Wing Guy's Avatar
Air Wing Guy
I get the codes 9360 and 9352 repeatedly when doing the odometer DTC thing. I even disconnected the batteries for an hour and they still remained. I'm totally stock so I can't figure out what they might be. '05 F250 PSD no mods.
onesr...push in your odometer reset button and hold while turning the ignition to "on" (not start) and wait momentarily for "test" to appear in the odometer display, release button and by pressing the button again you can go through a series of diagnostic and test modes. Press the button 15 or so times and any DTC codes will appear. It's kinda fun to mess with, you can get everyhting from coolant temp to a digital speedometer.
Old Jan 26, 2006 | 11:06 PM
clouden's Avatar
clouden
You really end up with a lot of "useless" info. unless you are one really looking for something. The 9352 code is one that is present on most all of the 6.0's and I can not honestly tell you what it means I speculate that it relates to putting the ignition circuit into test mode, but not sure. I only know that you need not worry about that one. Also, I cranked the truck up the other day while in test mode, and it threw a lot of codes, 9352, d027,d262,d059,d073,d058....most of which relate to the pcm not recieving the correct or needed data, due to, i think, the test procedure and starting the engine at the same time.
Old Jan 27, 2006 | 07:43 AM
Tdusseau's Avatar
Tdusseau
Run mine in test mode all the time, like to check Temp on cold start-up. No codes thrown on mine. '05 250 cc/sb fx4
Old Jun 3, 2006 | 09:11 PM
cwocg's Avatar
cwocg
what is error code 9360
Old Feb 2, 2012 | 05:12 PM
RJJP's Avatar
RJJP
9352 is a low battery power code, when you replace the batteries it will set it.
Old Apr 29, 2025 | 02:49 PM
Fordsbolt's Avatar
Fordsbolt
1st Gear
Diagnostic
Mode
Displayed
DTC
Awesome but would you or could you be so kind as to share where you found these gems?
dougbrown
May 29, 2022 08:35 AM
SBV45
Aug 28, 2018 11:12 AM
Sgt93
6.7L Power Stroke Diesel
Feb 5, 2018 12:48 AM
wyoclint
Dec 15, 2016 05:02 PM
Jesser02EX
Sep 16, 2016 09:31 AM
