Ignition Box and Wiring
Old Jan 26, 2006 | 10:06 AM
Redneck-Cowboy's Avatar
Redneck-Cowboy
I recently redid my 6 banger with the 4 barrel setup and headers and etc. anyways my truck was an 86 and had the electronic dist but a carb, so I found an old vac advance dist. but am having a hell of a time getting the right ignition box that would wire in right, right now I'm on my 3rd try, somebody said I needed the one w/ a blue gromut on the bottom, so once that comes in I hope that's it b/c I've been messing with this for days now. The dist. actually came off a 79 and has a 3 prong female plug and I'm using the 86 coil, so any help here would be great, thanks
Old Jan 26, 2006 | 04:52 PM
Desperado82's Avatar
Desperado82
www.gofastforless.com and look for information on "Better Ignition" It will tell you how to wire up a GM ignition module! I works great but you need to bypass the resistor wire and use a hotter coil!
