Plywood carb spacer?
Am installing stock 302. Put on an iron 4bbl manifold (C8AE) and Holley 8007 carb. A spacer would help keep the control cables and fuel line off the manifold.
I read about the performance qualities in the archive section.
They don't look that complicated, and I saw where some have been made of plywood. I have plenty of scrap 3/4 inch birch (cabinet grade) plywood and access to a lot of tools.
Is this practical? Or is it one of billy-bob's-off-the-wall-ideas to save money? Just need to raise the carburetor an inch or so. Don't want anthing that will leak or catch fire.
The wood spacers have a performance advantage, but must be replaced regularly because they do absorb fuel. If your going stock, best stick with an aftermarket piece. Get a 4 hole, this will give better low end torque. The open ones seem to boost higher rpm horsepower.
If you want to get real crazy, you could make a bunch of spacers out of wood and see which one works best with your combo, they buy the plastic one.
cvorden
25
08-19-2016 07:07 PM
CharlieLed
16
08-03-2015 04:24 PM
karljay
Garage & Workshop
24
01-27-2006 12:37 PM
