Sponsored by: Auxito
Cold Air Intake Problems
Old Jan 25, 2006 | 09:27 PM
fredtheford's Avatar
fredtheford
Question Cold Air Intake Problems
I just installed a K&N Cold Air intake kit on my 99 F150 with a 4.6, everything is working great but every so often it will make a low pitched whistle noise comin from around the air filter, its reasonably loud, i installed everything just as it says except for the vent hose that goes down to the driverside valve cover. The noise only happens when i come to a stop to turn or park, it never happens when i am just drivin along, it goes away if i give it some throttle, any advice would be great!
Old Jan 26, 2006 | 08:06 AM
BillyBob69's Avatar
BillyBob69
From what I have heard, the whistling is the nature of the beast. I am sure someone else will chime in here.....
Bump!
Old Jan 26, 2006 | 09:18 AM
fredtheford
Exclamation low fog horn sound from cold-air intake
The whistle you are talking about as being normal is there too, that is not what is bothering me, its a very loud and low noise, almost like a sick fog horn, looked at some previouse threads on the topic and they seemed to say that it may be the cold temps, i live in northern Indiana and its about 20 degrees right now, they said that the cold temps may be causing something to stick inside or something
Old Jan 26, 2006 | 10:54 AM
BillyBob69's Avatar
BillyBob69
MAF sensor?
Old Jan 26, 2006 | 12:58 PM
Chrisrock3's Avatar
Chrisrock3
I put a cold air intake in my 2001 5.4 and it whistled for a few months. I noticed that 1 of the 2 Vac lines that is connected to it was bent/kinked. once I straightened it the whistle went away and never came back. To do this I had to install an elbow where the kink was.
Lucas0168
1997 - 2003 F150
30
Jul 19, 2012 01:20 PM
highteckredneck
1997 - 2003 F150
50
Nov 26, 2009 04:06 PM
rtazz17
20
Oct 24, 2009 05:17 PM
Siggy1
Aftermarket Products
May 6, 2007 09:42 AM
Mikes67F250
Modular V8 (4.6L, 5.4L)
May 20, 2006 08:33 AM
