Screech noise after cold air intake install
Installed a s & b cold air intake couple weeks ago. I have noticed a best described as a screetching noise when the truck shifts or I let off the gas. Its a momentary thing and goes away quickly. I dont think its surge, its not happening under load and doesnt begin to buck or stall, but its most certainly related to the cold air intake install... Any ideas?
And its related to too much air?Any way to stop it without spending a fortune? I thought more air was better for your truck?What exactly is happening to make it screetch? Hopefully im describing the sound correctly cause it really doesnt sound like barking.. Just high pitched screetch almost like a loose belt noise...But i know its not a belt, new belt and happened right after intake install
hhmmm... Did you check to make sure your wheel doesn't have too much play? First thing I would do is pull the intake and see if the wheel is hitting the housing. If it's not, then the barking noise is normal, but is usually described more like a Darth Vader breathing. What's happening is that as you push all that air in with the turbo when you're in the upper RPM range, it has to go somewhere as the engine & turbo RPM drop when you shift. It just comes back out the intake, which you probably just didn't hear with the stock intake.
The intake wheel itself isn't the problem (unless it's chewed up and needs replaced). The issue is worn turbo thrust bearing/bushings. You can get a rebuild kit which replaces all those wear items and you'll have essentially a brand new turbo. Several of us here have rebuilt our turbos -- it's easily done with simple hand tools.
Mine started doing that after I did the air filter mod. I don't think it's actually doing anything new, I think I can just hear it now since the stock air box is gone. It almost sounds like a blow off valve on a turbo charged gasoline engine. I think it's just the sound of the turbo slowing down since the exhaust side of the turbo is seeing less flow when the fuel is cut. Probably just a pressure wave reflecting back up the intake tubing from hitting the turbo that is now slowed down. It's not very loud and unless I'm trying to do it, or have the window down I don't hear it.
Does this sound like what you are describing?
Im gonna assume this is my case as well..Whatever this noise is only appeared the first ride after cold air intake install..There is no loss of boost or hesitation ,only symptom is the noise and most of time its not noticeable.Ill pull the intake tube tomorrow just to make sure there is no play on the wheel..Other then that I guess I wont worry..
