Rebuild or replace my 361 XD?
Old Jan 25, 2006 | 02:53 PM
DouglasR's Avatar
DouglasR
Fellow members:
My 72 Ford L700 is in need of serious work.
With 330,000 VERY hard miles on it, the 361 XD blew a gasket, with much smoke, noise and fanfare. It was scary. The crankcase is now loaded with coolant, and the engine runs but is nearly dead, only about 3 cylinders are firing.
Question -
Should I replace with a Jasper or similar engine, or rebuild the original engine?
I don't know if this is the engine that came with the truck from the factory. It appears to be, but could have been replaced at some time in the past.
The rest of the truck is solid, and is a workhorse that doesn't know when to stop. Really built far tougher than it needs to be, but that's a good thing!
Ideas?
Comments?
Thanks
-Doug
Old Jan 25, 2006 | 03:06 PM
ford390gashog's Avatar
ford390gashog
the 389 was the only XD made. the 361 is just a regular FT.
Old Jan 25, 2006 | 03:38 PM
rusty70f100's Avatar
rusty70f100
I'd go ahead and rebuild it. It really isn't that much different than the standard FE rebuild. Just some parts differences. Might also be a good time to convert it to a 391, if you want to go that route.
Old Jan 25, 2006 | 04:26 PM
ford390gashog
a reman 391 is 1450.00 i would do that.
$Bruiser$
Sep 1, 2019 04:55 PM
1COOKIEMON
Mar 24, 2015 03:40 AM
alchemist1
Jan 31, 2014 08:00 PM
kgh
Large Truck
13
Oct 10, 2011 06:28 PM
mike L
22
Feb 1, 2010 11:45 AM
