Aerostar Ford Aerostar
Tranny swap
Old Jan 25, 2006 | 10:35 AM
A star's Avatar
A star
Tranny swap
I have a 94 rwd 3.0 which runs very well, except for a slight thump when it shifts from 1st and 2nd gears. I also have a 90 rwd 3.0, which I parked when I got the 94 about 3 months ago. The junkyard computer said that the two trannies are not interchangerable. My question is, can I put the 90 tranny in the 94 if I change the bellhousing, etc. I want to keep the 90 tranny for a backup if I can use it.
Thanks!
Old Jan 25, 2006 | 10:45 AM
Bear River's Avatar
Bear River
Former ******
Depends on whether or not the trannies are both A4LD. If they are, then they will swap no problem. However, rough shifting has a lot of causes, and swapping trannies doesn't sound like much of a plan. Basic maintenance may be all it needs, new fluid, filter, basic flush, and new modulator. If that doesn't work, then you really didn't waste your money, unless you plan to get rid of it anyway.
Old Jan 25, 2006 | 11:33 AM
A star's Avatar
A star
At the risk of showing my IQ, how do I tell if both trannies are A4LD?
Old Jan 25, 2006 | 01:22 PM
Bear River's Avatar
Bear River
Former ******
Uhm, maybe we should wait for someone on this forum who knows what years the A4LD was found. I don't know which years were the changeovers.
Old Jan 25, 2006 | 01:24 PM
copper_90680's Avatar
copper_90680
Look at the oil pan and count the number of bolts. They should be the same. I believe the A4LD does not change until late '95 and later.
Old Jan 25, 2006 | 03:03 PM
96_4wdr's Avatar
96_4wdr
lot of back busting work to change two tranny's....check the one in the '94...has many of the upgrades and improvements made to A4LD....drop pan...change filter...check for metal cutting and amount of worn off friction material in pan bottom...drop valve body and clean- check 1-2 shift valve...put in new servos and modulator...adjust bands....do 10 qt ATF change
Old Jan 25, 2006 | 09:27 PM
A star's Avatar
A star
Thanks guys for your time and suggestions. You have been most helpful. I will service the 94 transmission and see what happens.
Old Jan 27, 2006 | 02:52 AM
93nighthawk's Avatar
93nighthawk
Welcome!
Yes they are both the same (A4LD.) The tranny did not change until very late 95 model year and the easiest way to tell the difference is to look at your shifting choices. If you of OD D 2 1 then it is an A4LD, if it is OD 2 1, then it is a 4r44e or 5r55e depending on engine and year.
I agree, first thing, due a fluid/filter change and make sure level is where it should be. Too much or too little causes the A4LD to do wacky things.
