Homemade locker
Old Jan 25, 2006 | 08:46 AM
f250 big block's Avatar
f250 big block
Homemade locker
I have a dana 60 that grenaded on me. I broke one of the spider gears and the pin in it. The gears that have the splines are undamaged, would it be possible to weld them directly to the metal sleeves in the cast carrier ? Would the metal sleeves spin ? would the cast be weakened and break ? it see's about 99% off road. Am i just going to have a bigger problem later (cracked housing) Thanks
Old Jan 25, 2006 | 09:13 AM
User 71024's Avatar
User 71024
Solid axle is not a good idea, you'll tear it up pretty quick.
Old Jan 25, 2006 | 09:18 AM
f250 big block
But wouldn't it be the same as a spool or locker ?
Old Jan 25, 2006 | 09:44 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
it would be the same as a spool pretty much, which makes it a bad idea if you drive it on the pavement.....plus its harder on axles and hubs....now ive heard of people welding the fronts, and just unlocking one hub until they need both front wheels....but thats just something i heard, i dont know how safe it is to do....
Old Jan 25, 2006 | 09:57 AM
f250 big block
it only see about 1% of pavement and that is when I load in on the trailer, other than that its in dirt
Old Jan 25, 2006 | 10:28 AM
highboy390fe's Avatar
highboy390fe
I have my dana 60 front welded and numerous other people in the Offroad forum do also.
Old Jan 25, 2006 | 12:05 PM
ivanribic's Avatar
ivanribic
I don't remember off the top of my head if the sleeves spin or not but I know you can weld those gears directly to the carrier with no problems.
We call this a Lincoln Locker.
Old Jan 25, 2006 | 12:19 PM
f250 big block
That is what I did the last time, it lasted for about 1 year. And by no means was I easy on the gears. It was just another cheap way to get me back for the weekend
tjmike
Feb 27, 2016 08:19 PM
NICKSAN
Jan 23, 2016 05:21 PM
BRay09
Dec 30, 2015 06:11 AM
BGF100
Aug 29, 2015 07:51 PM
Papas66
Jan 15, 2014 10:05 PM
