Modular V10 (6.8l)
failed inspection
Old Jan 27, 2006 | 02:52 PM
ajordan193's Avatar
ajordan193
well after arguing with the shop for a few hours i finally have an new york state instpection. What happened is the truck was registered wrong due to the previous owner so the weights didn't match what the state had and what the truck was weighted at. they were doing 0-8,000 something and it was supposed to be 8000-10000. So partly my fault with the registration but we got stuff worked out and i got a go-ahead from the state to pass inspection. If the shop would have compared the 2 numbers they would have known. Supposely for emmissions you only need 4 outta 6 to pass with my weight and they were doing 6 outta 6 and it didn't pass because something is still wrong with the computer. I'm going to have to make an appt. with the dealer to see what they can do with the computer. I was told that i might have a warrenty left something like 8 years on the computer is this right? also i'm the 2nd owner of this truck so i dont' kno if that counts. Thats where i stand now, i'm just happy its inspected and i can drive her. Thanks for all your help on this topic this is a great site!
-Andrew
Old Jan 27, 2006 | 05:22 PM
RAMBOv10's Avatar
RAMBOv10
This is some of what a tech has to do to clear the p1000, of course someone who owns the truck will probly get the code cleared from there normal driving. Of course my understanding is after you disconnect the battery you will get the code again till the drive cycle is finished. Below is some info I found on clearing p1000......also there is no warranty invlolved in clearing a p1000.
Daniel
<TABLE cellSpacing=20 cellPadding=2 width="80%" border=0><TBODY><TR><TD vAlign=bottom align=middle width="25%"><SMALL>Purpose of</SMALL>
<SMALL>Drive Cycle Procedure</SMALL>
</TD></TR><TR><TD vAlign=top align=middle width="15%"><SMALL>Drive Cycle</SMALL>
<SMALL>Preparation</SMALL>
</TD><TD vAlign=top width="60%"><SMALL>1. Install scan tool. Turn key on with the engine off. Cycle key off, then on. Select appropriate Vehicle & Engine qualifier. Clear all DTC's/ Perform a PCM Reset.</SMALL></TD><TD vAlign=top width="25%"><SMALL>Bypasses engine soak timer. Resets OBDII Monitor status.</SMALL></TD></TR><TR><TD vAlign=top align=middle width="15%"></TD><TD vAlign=top width="60%"><SMALL>2. Begin to monitor the following PIDs: ECT, EVAPDC, FLI (if available) and TP MODE.</SMALL>
<SMALL>Start vehicle WITHOUT returning to Key Off.</SMALL>
</TD><TD vAlign=top width="25%"></TD></TR><TR><TD vAlign=top align=middle width="15%"></TD><TD vAlign=top width="60%"><SMALL>3. Idle vehicle for 15 seconds. Drive at 64 Km/h (40 MPH) until ECT is at least 76.7°C (170° F).</SMALL></TD><TD vAlign=top width="25%"></TD></TR><TR><TD vAlign=top align=middle width="15%"><SMALL>Prep for Monitor Entry</SMALL></TD><TD vAlign=top width="60%"><SMALL>4. Is IAT within 4.4 to 37.8°C (40 to 100° F)? If Not, complete the following steps but, note that step 14 will be required to "bypass " the Evap monitor and clear the P1000.</SMALL></TD><TD vAlign=top width="25%"><SMALL>Engine warm-up and provide IAT input to the PCM.</SMALL></TD></TR><TR><TD vAlign=top align=middle width="15%"><SMALL>HEGO</SMALL></TD><TD vAlign=top width="60%"><SMALL>5. Cruise at 64 Km/h (40 MPH) for up to 4 minutes.</SMALL></TD><TD vAlign=top width="25%"><SMALL>Executes the HEGO monitor.</SMALL></TD></TR><TR><TD vAlign=top align=middle width="15%"><SMALL>EVAP</SMALL></TD><TD vAlign=top width="60%"><SMALL>6. Cruise at 72 to 104 Km/h (45 to 65 MPH) for 10 minutes (avoid sharp turns and hills) Note, to initiate the monitor: TP MODE should =PT, EVAPDC must be >75%, and FLI must be between 15 and 85%</SMALL></TD><TD vAlign=top width="25%"><SMALL>Executes the EVAP Monitor (If IAT is within 4.4 to 37.8° (40 to 100°F))</SMALL></TD></TR><TR><TD vAlign=top align=middle width="15%"><SMALL>Catalyst</SMALL></TD><TD vAlign=top width="60%"><SMALL>7. Drive in stop and go traffic conditions. Include five different constant cruise speeds, ranging from 40 to 72 Km/h (25 to 45 MPH) over a 10 minute period.</SMALL></TD><TD vAlign=top width="25%"><SMALL>Executes the Catalyst Monitor.</SMALL></TD></TR><TR><TD vAlign=top align=middle width="15%"><SMALL>EGR</SMALL></TD><TD vAlign=top width="60%"><SMALL>8. From a stop, accelerate to 72 Km/h (45 MPH) at 1/2 to 3/4 throttle. Repeat 3 times.</SMALL></TD><TD vAlign=top width="25%"><SMALL>Executes the EGR Monitor.</SMALL></TD></TR><TR><TD vAlign=top align=middle width="15%"><SMALL>SEC AIR/CCM (Engine)</SMALL></TD><TD vAlign=top width="60%"><SMALL>9. Bring the vehicle to a stop. Idle with transmission in drive (neutral for M/T) for 2 minutes.</SMALL></TD><TD vAlign=top width="25%"><SMALL>Executes the ISC portion of the CCM.</SMALL></TD></TR><TR><TD vAlign=top align=middle width="15%"><SMALL>CCM (Trans)</SMALL></TD><TD vAlign=top width="60%"><SMALL>10. For M/T, accelerate from 0 to 80 Km/h (o to 50 MPH), continue to step 11. For A/T, from a stop and in overdrive, moderately accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop vehicle and repeat without overdrive to 64 Km/h (40 MPH) cruising for at least 30 seconds. While at 64 Km/h (40 MPH) , activate overdrive and accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop for at least 20 seconds and repeat step 10 five times.</SMALL></TD><TD vAlign=top width="25%"><SMALL>Executes the transmission portion of the CCM.</SMALL></TD></TR><TR><TD width="15%"><SMALL>Misfire & Fuel Monitors</SMALL></TD><TD width="60%"><SMALL>11. From a stop, accelerate to 104 Km/h (65 MPH). Decelerate at closed throttle until 64 Km/h (40 MPH) (no brakes). Repeat this 3 times.</SMALL></TD><TD width="25%"><SMALL>Allows learning for the misfire monitor.</SMALL></TD></TR><TR><TD width="15%"><SMALL>Readiness Check</SMALL></TD><TD width="60%"><SMALL>12. Access the ON-Board System Readiness (OBDII monitor status) function on the scan tool. Determine whether all non-continuous monitors have completed. If not, go to step 13.</SMALL></TD><TD width="25%"><SMALL>Determines if any monitor has not completed.</SMALL></TD></TR><TR><TD width="15%"><SMALL>Pending Code Check and Evap Monitor "Bypass" Check</SMALL></TD><TD width="60%"><SMALL>13. With the scan tool, check for pending codes. Conduct normal repair procedures for any pending code concern. Otherwise, rerun any incomplete monitor.</SMALL>
<SMALL>Note: if the EVAP monitor is not complete AND IAT was out of the 4.4 to 37.8° C (40 to 100° F) temperature range in step #4, or the altitude is over 2438 m. (8000 ft.), the Evap "bypass" procedure must be followed.</SMALL>
<SMALL>Proceed to step 14.</SMALL>
</TD><TD width="25%"><SMALL>Determines if a pending code is preventing the clearing of P1000.</SMALL></TD></TR><TR><TD vAlign=top align=middle width="15%"><SMALL>Evap Monitor "Bypass"</SMALL></TD><TD vAlign=top width="60%"><SMALL>14. Park vehicle for a minimum of 8 hours. Repeat steps 2 through 12. DO NOT REPEAT STEP 1.</SMALL></TD><TD vAlign=top width="25%"><SMALL>Allow the "bypass" counter to increment to two.</SMALL></TD></TR></TBODY></TABLE>
Old Jan 27, 2006 | 09:29 PM
captchas's Avatar
captchas
Guest
Originally Posted by ajordan193
are u serious...what speed am i supposed to go to and drop down to? i'm taking it back today at 1pm i'm hoping it passes i've up over 100 miles on the past 2 days both city and highway so i hope it reset by now. My superchips programmer is not going back in..if interested contact me.
-Andrew
the tuner is only good for your truck , when first used they lock up on the vin from inside the pcm which also holds the true milage
Old Jan 28, 2006 | 12:06 AM
ajordan193's Avatar
ajordan193
not true. You can only use it on one truck at a time. Right now my truck is back to being stock and the tuner can be hooked up to any V8/V10 gasser 96-present. www.superchips.com explains it all.
-Andrew
Old Jan 28, 2006 | 07:16 AM
captchas's Avatar
captchas
Guest
mine is vin locked i can't sell it. or use it on another car or truck .it will not hold 2 stock tunes or code numbers
Murfy101
3.8 & 4.2L V6
Oct 1, 2015 06:23 PM
Murfy101
Oct 1, 2015 05:55 PM
ap67et10
New Member Introductions
Apr 15, 2014 08:30 AM
1984F150Guy
30
Mar 7, 2014 12:11 PM
White76
Paint & Bodywork
Mar 5, 2014 05:11 PM
