Sponsored by: Auxito
98 5.4 running really bad with 3 codes
Old Jan 24, 2006 | 08:36 PM
cdj98f150's Avatar
cdj98f150
Cool 98 5.4 running really bad with 3 codes
i have a 98 f150 4x4 with the 5.4, it is stuttering bad when a little acceleration, had codes pulled and they are p0155, p0401, and p0174, can anyone help me here, thanks
Old Jan 24, 2006 | 09:10 PM
wolfman01's Avatar
wolfman01
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0174 System too Lean (Bank 2)
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
I'd check the O2 sensor first. The second code is telling me that it is no longer sending any information to the computer, causing it to call out the too lean condition. This could also be sending the EGR system out of whack as the conflicting sensor information is giving the system fits as the computer tries to fatten up the mixture to account for the bad sensor. I don't know what the correct resistance is for the sensor to test, unfortunately.
Old Jan 24, 2006 | 09:49 PM
mat-helm's Avatar
mat-helm
I've got a question, is bank 2 sensor 1 the pass side front one? If it is, your best bet is to just change it ( about $50 at Advance), and you'll need a 7/8 wrench ( they make a special socket for that because of the wires and the fact that they don't like to come out most times), and I like to remove the plastic inner fender (makes it a whole lot easier to get to).
Old Jan 24, 2006 | 10:47 PM
wolfman01's Avatar
wolfman01
I'm not sure, but I'd hazard a guess to say that bank one would be cylinders 1-4, and bank 2 would be 5 - 8
Old Jan 24, 2006 | 10:56 PM
wmcnally's Avatar
wmcnally
Do a search on PO401. A vacuum leak to the EGR system could cause all 3 of thoe codes.
Old Jan 25, 2006 | 07:41 AM
projectSHO89's Avatar
projectSHO89
Established protocol tells you to address the codes one at a time, in the order they were issued by the scanner. Fix the first one, then test for any remaining faults.
That said, I suspect you actually have three separate faults:
1) Heater circuit open upstream sensor driver's side. Check the sensor's connector for corrosion first. Test the sensor's heater for an open circuit with an ohmmeter. Replace if open. The heater is only used during cold engine startup so that the sensor can operate sooner and allow the PCM to switch to closed loop operation sooner. Emission control strategy.
2) Likely vacuum leak.
3) EGR ports clogged or DPFE faulty. (Two most common reasons for the P0401).
You probably still have a yet undeclared misfire.
Steve
Old Jan 25, 2006 | 08:37 AM
mat-helm's Avatar
mat-helm
Tuvok?!?....... is it really you?....
Old Jan 25, 2006 | 02:49 PM
cdj98f150's Avatar
cdj98f150
well, went to the dealer today and wow!! they came up with the following: 2 ignition coils need replaced, all plugs, 6 other cop boots, dpfe hoses change, and dpfe sensor change, and clean egr ports. their total for all of this is 548 parts, 982 labor and a little others total is like 1763.19 then the guy said that something else would probly go wrong when all this was fixed, if anyone can help please let me know
Old Jan 25, 2006 | 03:01 PM
mat-helm's Avatar
mat-helm
lol, that serves writer just went down the list, I'm supprised he didn't put new catalytic converters on that list. Pick any one of the replies above and have at it. Do a search of the forum for "how to's" on any given part.
Old Jan 25, 2006 | 10:25 PM
wmcnally's Avatar
wmcnally
Originally Posted by cdj98f150
they came up with the following: 2 ignition coils need replaced, all plugs, 6 other cop boots, dpfe hoses change, and dpfe sensor change, and clean egr ports.know
If I had this problem, I'd replace the DPFE myself. Change the attached hoses. Check/replace all vacuum hoses to the EGR system. As I mentioned above a vacuum leak will account for the lean code and set O2 senser codes and account for the EGR flow code.
After replacing the DPFE etc. Clear the codes and drive for a few cycles. If the CEL lights up again have the codes read again and post them here.
Good Luck
