TTB- Dana 60 conversion question
Old Jan 24, 2006 | 08:08 PM
99ranger4x4's Avatar
99ranger4x4
I want to switch the TTB in my 1990 Ford F-250 4X4 to a dana 60. I found this axle on ebay. It has the right gearing, but it is out of a 1995 F-350. Will it work or will it be too wide, short ect...
eBay Motors: FORD DANA 60 FRONT AXLE (item 8032434357 end time Jan-29-06 11:15:50 PST)
Thank you for your time.
Old Jan 24, 2006 | 09:06 PM
Mustangsean's Avatar
Mustangsean
The issue isn't really width, but front suspension type. If you have coil springs, get ready for a lot of work (see my gallery). However, if you have leaf springs, then it's just an unbolt the TTB and bolt in the D60. Also, you'll need 8-lugh wheels.
Sean
Old Jan 24, 2006 | 09:45 PM
DaveBowman's Avatar
DaveBowman
Well since his is an F250, it will have leaf springs. It will also have the 8 lug wheels too. So your in luck, just bolt the axle in
Old Jan 24, 2006 | 11:10 PM
Mustangsean
DOH! Didn't see that...ok, just bolt the sucker in.
Sean
Old Jan 25, 2006 | 06:15 AM
93f250-44cepeks-olf-olf's Avatar
did the same conversion on my truck. very easy. all bolt on.
Old Jan 25, 2006 | 02:47 PM
beattle55's Avatar
beattle55
I've heard that it is important that the dimension from the center of the axle to the flange on the yoke is the same, otherwise you may have to shorten the front driveshaft.
Old Jan 25, 2006 | 09:14 PM
DaveBowman's Avatar
DaveBowman
Shouldn't matter too much. The driveshaft might only push the slip shaft in or out 1/8" for different differential positions on the earlier and later Dana 60 axles.
Dutter 2
15
Dec 9, 2016 07:26 AM
ranger_
33
Oct 19, 2016 09:04 PM
superdutymark
21
Dec 29, 2015 05:52 AM
dohc_chump
46
Aug 9, 2015 03:57 AM
atomicjoe23
Oct 13, 2008 10:58 PM
