3.03 to C4
Old Jan 24, 2006 | 07:07 PM
fordflaresides's Avatar
fordflaresides
3.03 to C4
I want to convert my 1978 F100 2WD 300 6 cyl from a 3.03 manual transmission to a C4 automatic. I know I will need the transmission, flywheel, torque converter, speedo cable, cooling lines, shifter w/ linkage and a new radiator. Am I missing any parts? Also, does the 3.03 use the same splines as a C4, I know I will probably have to have the driveshaft cut or lengthened but was wondering if I needed a different spline pattern too?
Old Jan 24, 2006 | 07:43 PM
havi's Avatar
havi
I'll have the Roast Duck
are you talking shifter as in floor shifter? cuz that would be easier than trying to work with the column. you'll need to pry out the pilot bearing from the back of the block. speedo cable might be the same as long as the length reaches. splines? use the same yoke on the c4 and grab the driveshaft out of the donor truck too.
Asian Al Bundy
Mar 25, 2013 12:55 AM
bulletsneverlie
27
Aug 9, 2009 01:52 AM
Trustee
May 23, 2009 09:34 PM
80F-100 2wd
22
Mar 5, 2009 05:37 AM
