Oil Leak
Old Aug 9, 2001 | 07:55 PM
olthunter's Avatar
olthunter
Oil Leak
a week (500 miles)after i put a new engine in my dad's 78 f-100, i noticed an oil leak dripping out of the bellhousing at the bottom between the bellhousing and that metal "gasket" between the engine and bellhousing. it's not a lot it dripps for a few minutes after the truck has stopped then stops. to the best of my knowledge there shouldn't be any oil at all in the bellhousing. there is oil all over the outside of the bellhousing and some on the tranny. also the boot that covers the arm that engages and disengages the tranny is covered. i was wondering if any one of you has experienced this problem or have any solutions to this? i would like to know before i have to lift the engine out and check the engine and do something major. thanks for your time.
Old Aug 9, 2001 | 08:56 PM
FastPony's Avatar
FastPony
Oil Leak
Its probably a rear main seal on the engine.
Old Aug 9, 2001 | 09:08 PM
85351ho's Avatar
85351ho
Oil Leak
look behind the intake and see if its not the rear intake gasket, if theres no oil on the top of the bellhousing, it could be the rear cam freeze plug thingy, or rear main
1985 F-150/351Ho/c6/4wd~94,000 miles
1979 F-150extcab4x4/460/c6/6inchlift w/60rear44frnt (250 axles and springs)
37 inch boggers
Old Aug 10, 2001 | 02:05 AM
60f100trk's Avatar
60f100trk
Oil Leak
the rebuilt engine i got i bought outa the paper and it had sat a long time.
it used to leak pretty good when i first put it in, especially after long trips.. then it would go away
i was sure the rear main was bad,
then it sorta just went away, i havent seen any oil in the driveway for awhile
Old Aug 10, 2001 | 05:12 AM
jowilker's Avatar
jowilker
Oil Leak
St8_6pwr
Jun 5, 2013 08:35 PM
carlsson
Oct 8, 2009 09:46 AM
pumps
May 31, 2006 05:11 PM
ms_michelle
401, 477, & 534 SD Engines
Aug 25, 2004 09:16 AM
rleeds
18
May 15, 2003 08:58 AM
