check engine code
Old Jan 24, 2006 | 02:21 PM
ncbeachboy173's Avatar
ncbeachboy173
check engine code
where can i find out what code 1400 is ,this is the code that was told to me as to why my check engine light is on .....can you help? it is a 1998 ranger 3.0 but the engine is a yr 2000 3.0
Old Jan 24, 2006 | 03:40 PM
el conquistador's Avatar
el conquistador
try this:
https://www.ford-trucks.com/lc/lc.ph...ery%2FDTCs.pdf
Old Jan 24, 2006 | 04:35 PM
ncbeachboy173
check engine light
Now that i found out what code was causing my check engine light to come on ,how do i fix it ? the code is 1400 it is the differential pressure feedback electric sensor circit low voltage ....what does that mean ,and or, how do you fix the problem ....thanks
Old Jan 24, 2006 | 07:59 PM
Ken00's Avatar
Ken00
The DPFE senser is a common failure, do you have a metal or plastic senser? Also make sure the hoses are not cracked/damaged.
Old Jan 24, 2006 | 11:20 PM
ncbeachboy173
i dont know where it is even located ,thanks for the reply
Old Jan 25, 2006 | 07:29 PM
Ken00's Avatar
Ken00
Check out the link in the tech info thread at the top of this forum, "more DPFE senser testing".
