AC SHOP MAN
Old Aug 8, 2001 | 12:45 PM
rlehman's Avatar
rlehman
AC SHOP MAN
Anyone out there with a shop manual for 74 F250 390? My question is, does the ambient air temp sensor pass through the evaporator or does it reside completly on the cab/warm air side of the evaporator? My AC cycles excesivly, about every 30 seconds after the cab cools down, I read somplace that the snesor could be to close to the evaporator and short cycling the compersor. I have pulled the wire away from the Evap but there seems to be more. My sensor passes through to the other side??? Maybe somone could take a look at there cab side and let me know, or maybe I should quite being so cheep and get one of those CD shop manuals.
Thansk Bob, plenty hot in MD
Old Aug 10, 2001 | 02:13 AM
karljay's Avatar
karljay
AC SHOP MAN
The sensor goes in between the fins and goes back to a little box that has two small holes in it. Look inside the two small holes and you'll see adjusting screws. They adjust when it goes off and how long it goes before it restarts. I had mine completely apart and tested it using my freezer.
If you like where it starts to cycle (you think it's cold enough) then adjust one of the screws to allow it to stay off longer before coming back on.
The main use is to keep of from icing up.
Also, they have a sensor in front of the rad that will turn off the AC when outside is < 70 deg.
Old Aug 11, 2001 | 08:44 PM
rlehman's Avatar
rlehman
AC SHOP MAN
Thanks for the info, How do I access the the small box with adjusting screws?
Bob L
Old Aug 12, 2001 | 01:32 AM
karljay's Avatar
karljay
AC SHOP MAN
You should have about 8~10 screws holding a cover on the box. These go thru the firewall and hold the box up. Once you remove that cover, I think it's either right there or behind a steel plate. I think it's about 1.5"x1". You'll see a wire(s) connected to it.
Old Aug 12, 2001 | 01:48 AM
Boss_358's Avatar
Boss_358
AC SHOP MAN
jrt2nd
May 27, 2013 08:50 AM
Rollbar
1997 - 2003 F150
Jun 25, 2009 03:47 PM
Club Wagon
13
May 7, 2007 04:26 AM
Amey914
1983 - 2012 Ranger & B-Series
Aug 26, 2004 05:46 PM
beerguy5810
Jun 2, 2004 03:09 AM
