Aerostar Ford Aerostar
Getting "Hosed" Electrically
Old Jan 24, 2006 | 09:54 AM
96_4wdr's Avatar
96_4wdr
did your cooling system turn into a giant corrosive battery?
http://www.gates.com/brochure.cfm?brochure=1023
Old Jan 24, 2006 | 10:35 AM
aerocolorado's Avatar
aerocolorado
Replacement recommended every 2 to 4 years? That strains Gates' credulity and makes me think we might be getting "hosed" in another fashion. Interesting article, but I would take it with a grain of salt considering its target audience.
Old Jan 24, 2006 | 11:07 AM
Pablo-UA's Avatar
Pablo-UA
I have original ('89!) old hoses! And I have no any problem! My engine was rebuilt! But hoses are OK! Dont toch it if you have no leaks, overheating or other problemes, just wash radiator and motor inside every 2-4 years ... If you can see your hoses damaged or too old replace.
Old Jan 24, 2006 | 07:17 PM
krankshaft's Avatar
krankshaft
Same here 96 Aero 3.0 and haven't replaced a single hose they are still soft and malleable with no cracks.
Old Jan 24, 2006 | 09:35 PM
96_4wdr's Avatar
96_4wdr
Thar She Blows
http://www.gates.com/brochure.cfm?br...cation_id=3369
Old Jan 24, 2006 | 09:44 PM
cbr900's Avatar
cbr900
I have had to replace quite a few hoses here in florida because even when engine is not running the outside air temp cooks them.
Old Jan 26, 2006 | 05:09 AM
Pablo-UA's Avatar
Pablo-UA
Before aero I used to drive Tavria (small Ukrainian sedan of Ford fiesta of Honda-civic size). I replaced upper hose after 4 years of use (because of leakage). Its hot in summer there (up to 40dgr C) and its about -10dgr C in winter. But my friend drives BMW and he replaces hoses every 2 years...
Old Jan 26, 2006 | 06:34 PM
cbr900's Avatar
cbr900
When I lived in england I hardley ever had to replace hoses, I do think climate has a lot to do with how long they last and the quality of the water in your area, ie is it hard or soft, in england were I lived the water was quite hard meaning it was less acidic. But then if you always run with antfreeze in your system it should protect against any nasties in the water as it is also an inhibitor.
Old Jan 27, 2006 | 01:10 AM
Pablo-UA's Avatar
Pablo-UA
As I remember using water (not antyfreeze) is not reccomended for aero, but there are some cars and trucks disighnet for water (but blue ore green antyfreeze is reccomended). Well known GAZ 2.5R4, 4.25V8, 5.5V8 motors are made of alluminiun. Its temperature is about 80-85dgr C. But I saw rusted alloy blocks!
Old Jan 27, 2006 | 06:45 AM
96_4wdr's Avatar
96_4wdr
either alkaline or acidic tap water is corrosive in cooling system...also antifreeze does break down and form corrosive compounds
Old Jan 31, 2006 | 09:31 PM
occupant's Avatar
occupant
TL-DR, but I remember reading somewhere about grounding out your cooling system and heater core to prevet corrosion. Happens more often than not in 98-up Crown Vics. I think we put 3 or 4 heater cores in Yellow Cab Y-265 before I finally tacked some grounding straps on the core, the radiator, and the engine block, and never had to change it after that.
