Sponsored by: Real Truck
HP?, automatic VS standard
Old Jan 23, 2006 | 05:46 PM
kurthb's Avatar
kurthb
If one were to dyno 2 trucks, idential except for their transmissions, how would the results be?
My take is that a manual requires less HP than it's automatic's counterpart.
Comments?
Old Jan 23, 2006 | 06:29 PM
Ford Truck Racer's Avatar
Ford Truck Racer
Automatics take more power cause of the pump it turns. After the torqure convertor is locked it is one to one so there is not loss there unless its unlocked.
Old Jan 23, 2006 | 06:33 PM
BareBones's Avatar
BareBones
Its not that simple. One main worth of a transmission is its ability to direct torque to the wheels, and an auto, at very low rpms supposedly "doubles" the taking-off power. At least, from a Ford perspective, the difference between an auto and a manual is that the auto is rated for 1,000 pounds greater GCWR.
Also, the autos seem to generally get better gas mileage, presumably because the computer does a better shifting job than people.
The manual though is cheaper, and to what is to me very important, most people can replace a pressure plate and a throwout bearing in a manual, whereas auto tranny repairs are almost always in the thousands of dollars when they do fail.
You pays your money and takes your chances.....
Old Jan 23, 2006 | 07:21 PM
kurthb's Avatar
kurthb
I would think in theory, any torque that the TC puts out needs to come from the crank, it does not create torque, so I guess you can think of it as spooling up torque and then having it there to start off, no?
Old Jan 23, 2006 | 09:50 PM
blakerj10's Avatar
blakerj10
Everything I have read about these trucks indicates the manual tranny generally gets 1-2 mpg better. I would attribute this to the fact that the engine is always "locked" to the manual tranny. I think the auto only locks up (from the factory) in 4th and 5th. While the slipping of the auto does multiply torque at lower speeds, it also uses more fuel per distance moved.While generally, from my auto and hotrod experience, an auto will usually suck more power on the dyno than a manual. Hower, the torqueshift is much more advanced and efficient than your typical C6 or E40D or even 4R100. I would suspect that on the dyno, two identical (except transmission) 6.0s would be much closer than a similar comparison of vehicles ten years ago.
Old Jan 24, 2006 | 05:01 AM
m350's Avatar
m350
I too believe the manual gets better mileage !
Old Jan 24, 2006 | 05:14 AM
ford390gashog's Avatar
ford390gashog
automatics have a torque multiplication factor of 2x in 1st gear.
Trevor1
May 24, 2007 03:59 PM
eric777
34
Mar 25, 2006 12:38 PM
led129
Feb 16, 2006 03:30 PM
canadianfordman
16
Dec 2, 2002 05:51 PM
