quick question, h-pipe and true duals?
Old Jan 23, 2006 | 05:14 PM
Vandal's Avatar
Vandal
im gonna dual my truck out, on my 93 f-150 ext cab, 302 v8 and im gonna run 3" pipe to 10-18" glass packs then run a short piece of 2.5" pipe to the tip and 45' it in front of both rear tires, i heard somethin about a h-pipe needed for true duals, is that true??
Old Jan 23, 2006 | 06:37 PM
slow_v6_stang's Avatar
slow_v6_stang
im not sure of the firing order on the 302, but if it has an even firing order, you can just run true duals without a crossover. if it is an odd firing order, then an H pipe or X pipe is a good idea.
Old Jan 23, 2006 | 06:41 PM
Vandal's Avatar
Vandal
thanks, anyone know the firing order? lol
Old Jan 23, 2006 | 07:32 PM
slow_v6_stang
as i said before, i do not know the firing order...but you might wanna go with 2.5" pipe instead of that 3" pipe. your low end is going to hurt with such little backpressure in your exhaust. on my mustang, when i went from the stock 2" single exhaust to the true duals with flowmaster 40's and 2.25" pipe, i noticed a decrease in the low end power.
Old Jan 24, 2006 | 08:23 AM
dk5122's Avatar
dk5122
You don't need an X-pipe or an h-pipe unless you have a high horsepower engine. Won't do a thing for you. True duals? What headers will you use? On a stock 302... 2 1/4" is plenty big. 3" will kill your low end power.
RAY1986F150
Jan 29, 2013 02:56 PM
73F100*8Mile
Exhaust Systems
13
Feb 22, 2006 09:19 PM
moose94
Exhaust Systems
Aug 23, 2003 09:28 AM
Stokes
Exhaust Systems
Jul 3, 2003 03:38 PM
