Loud Clicking
Old Jan 23, 2006 | 04:12 PM
Beckerhick's Avatar
Beckerhick
Exclamation Loud Clicking
I am in serious trouble, i think. Yesterday i drove my truck cold because i needed to get somewhere quick. Now this morning when i went out to warm my truck up, there was a loud clicking noise as soon as i started it. I opened up the hood and checked the fan and belts, but it more sounded like it was coming from the carb area. I myself am thinking that i bent a rod.
Old Jan 23, 2006 | 05:28 PM
big hoss 29's Avatar
big hoss 29
Welcome to FTE! If it was a bent rod, it would be louder than a clicking sound. It'd sound more like a diesel when it idles. What kind of engine do you have? What kind of carb? We need some more info to be able to help you pinpoint the trouble your'e having.
Old Jan 24, 2006 | 10:18 AM
fordborn's Avatar
fordborn
Welcome to Ford Truck Enthusiasts. We are glad you chose to visit our site. In order to make it easier to navigate please read the following.
Please view the main forum page to find the best forum to ask any Technical questions
Also, below some of the titles of forums there is text that explains what the forum is either for or what shouldn't be posted in it.
Then ,Inside certain forum's there could be a Read First: thread or threads attached to the top.
Please read these threads before posting.
In Addition to the Tech Forums all user's can make their relationship closer to others by visiting & joining the State/Province Chapter that relates to their location.A complete list of Chapter's is located on the main forum page, near the bottom.
Once again...Welcome to the FTE Family
What engine are you running. It might help to put the question in the engine tech forum for help.
Old Jan 25, 2006 | 08:01 AM
victorcharlie's Avatar
victorcharlie
Might be a rocker arm that need adjusting........a cheap stethoscope would be good to have as you can listen around on the engine to help find where it's coming from. Might just be a rocker arm that need adjusting. I've had good luck at removing the noise by replacing the nuts that hold the rocker arms on and then adjusting the valves. Lots of people blame the noise on a lifter, but most if the time it can be adjusted out......
But, before you do all this, change the oil and filter and see if that helps.....
Old Jan 25, 2006 | 09:11 AM
Kalashtar's Avatar
Kalashtar
Mine made that noise for a while and it was the bottom 1/2 of the distributor distributor cap. It had a crack in it and was letting moisture in.
Old Jan 25, 2006 | 08:42 PM
Brendan Galligan's Avatar
Brendan Galligan
Mine had the same problem. I checked everything it was driving me crazy. I called a friend of mine who had the same truck about 10 years ago, now he has a newer one, he told me to check the speedometer cable. i was desperate so i gave it a go. As it turned out it was the speedo cable, somewhere along the line it wore away the insulation on the housing, the clicking sound was the cable 'whipping around' inside hte speedo housing. so i replaced the cable. now no more clicking and my speedo is more acurate. 2 problems, one solution. check it out... you maybe supprised
Old Jan 26, 2006 | 07:19 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Brendan to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 14, 2006 | 10:26 AM
Beckerhick's Avatar
Beckerhick
sorry ive been busy finding a different vehicle to use, it turns out that my wrist pin is just about busted. And it is a 300-6 with a dbl carb
