Will not Start after Engine Warms Up!
Old Jan 21, 2006 | 09:35 AM
bspurlock's Avatar
bspurlock
Unhappy Will not Start after Engine Warms Up!
I got a 1984 F250 with a 460, Holly 4 barrel. The truck will start fine when cold, but after the engine warms up it will shut off and not start again until the next day when it is cold. I've replaced the ignition box, distributor box, coil, spark plugs. When I pulled the new spark plug, they were burnt (black). I'm not a mechanic so is this caused by the carborator, or the ignition system? Any advise would great be apprecated.
Old Jan 21, 2006 | 09:58 AM
fordborn's Avatar
fordborn
Welcome to FTE and all it's glory . You are now part of the largest Ford Community on the net. Glad you chose to register and am sure your stay will be beneficial. Have a good time and see you on the Forums.
Besides all the great Tech forums here we also have local state chapters where people from the same area can get together for meets, parties, or just carry on general conversation. Take the time to check out the chapter in your local area.
To make it easier to navigate please read the Forum Guidelines.
Old Jan 21, 2006 | 01:00 PM
Dungeon_Master's Avatar
Dungeon_Master
Without actualy seeing it in action. It sounds like the choke might be sticking.
Old Jan 21, 2006 | 07:54 PM
Bdox's Avatar
Bdox
I agree about the choke... Black plugs=rich condition Fits the symptoms
Old Feb 13, 2006 | 08:30 PM
bspurlock's Avatar
bspurlock
Truck running now. But....
Thanks for the advise. I checked the carb. and the electric choke was not working. So I replaced it with a manual choke which seemed to really help. I also cleaned the distributor and it runs most of the time. But even with the manual choke, it will start one time idling fast then the next time you start it up it idles to slow. When it idles to fast it will warm up and then shut off and I have to wait 30 minutes before it will start again. Could it be the float not working right? and if so, is there anything that I need to be aware of before I take the front off the carb to check and replace the float if needed?
Old Feb 13, 2006 | 10:39 PM
Bdox's Avatar
Bdox
Are you saying that it dies after warm up with the choke fully open?
When it dies do you have any backfire either through the carb or the exhaust?
Does it die while idling or while driving? Under load or coasting?
Did you change the plugs which you said were black? If you start with clean plugs you can pull them out after it dies to see what they look like.
Give us some more info to go on.
Old Feb 13, 2006 | 11:32 PM
bspurlock's Avatar
bspurlock
Yes it dies after the choke is fully open (sometimes). No backfire, just shuts off like you turned the key off. Or it will run fine until you shut it off then won't start again until you let set for about 30 minutes.
I changed the plugs right after installing the manual choke, but I have not looked at them since. I'll check the plugs again and see if they are clean or not.
Someone mentioned vapor lock on the fuel line. It has the two line fuel system so I thought that keeps it from vapor locking. But I may cover the fuel line anyway and see if that helps.
Thanks for any advise. I've learned more about engines and carbs. with this truck than any other vehicle. Kinda frustrating, but at the same time kinda fun trying to figure it out. I never thought I would enjoy working on something like this, but it gets addictive. Just glad its not my primary transportation.
Old Feb 14, 2006 | 12:40 AM
Bdox's Avatar
Bdox
Vapor lock seems unlikely.... winter.... fuel return line... naah
Check or change your fuel filter?
Symptoms may fit a failing Electronic Engine Control, or EEC, but you said you changed the "ignition box" and "distributor box."
So check for spark at the plugs after it dies. Also, when it won't start, look down the carb and operate the throttle and look for jets of gasoline from the accelerator pump, to determine the presence of fuel.
Let us know what you find.
Old Feb 14, 2006 | 06:13 PM
0270's Avatar
0270
My 300 6 does the same thing... I just press the petal down and it fires up then.
