Sponsored by: Real Truck
Diesel Starter problems
Old Jan 23, 2006 | 02:38 PM
shughe40's Avatar
shughe40
I have a 2001 F250 diesel. On cold days my starter will not engage properly. It makes a sound as if the engine is running and I am trying to start the truck. I was wondering if I needed to change the entire started or is there something else I can do to fix the issue?
Old Jan 23, 2006 | 02:59 PM
Steve_250's Avatar
Steve_250
Original batteries? Get them tested.
Cheap way to start the troubleshooting.
Old Jan 24, 2006 | 05:46 AM
shughe40's Avatar
shughe40
The batteries are less than a year old. I can have them tested. Can the starter be tested correctly? The truck has 106K miles.
Old Jan 24, 2006 | 07:57 AM
Steve_250's Avatar
Steve_250
I believe the starter would have to be pulled to be tested. Someone else hopefully could shed more light on that.
Now that I read your post again, it kind'a sounds like you are describing a flat spot. Can you pull the cover and inspect the starter gear and flywheel?
