Offroad & 4x4
Another Gear Oil Question
Old Jan 22, 2006 | 11:31 PM
ramboss429's Avatar
ramboss429
Gotta run to town in the AM to the doctor. Need to pick up some gear oil for my diffs and tranny. How much does a 44 front, rear 60 and an NP435 hold? I've done a search but can't seem to find out much. Sounds like 85W90 is what everyone is running??
Old Jan 22, 2006 | 11:53 PM
76f150_4x4_360fe's Avatar
76f150_4x4_360fe
The tranny prolly holds 19.5 quarts and I think the 44 holds 3 or 4 on the 60 Im not sure but prolly 5 or so, the 435 trannys do vary urpon year, models and suck but those are my best guesses
Old Jan 22, 2006 | 11:56 PM
ford390gashog's Avatar
ford390gashog
the NP 435 holds 7 quarts. 19.5 is almost 5 gallons there is no way it holds 5 gallons.
Old Jan 23, 2006 | 12:00 AM
ramboss429's Avatar
ramboss429
Whats the proper way to get all the old fluid out of the NP435. There is a lil square panel on the side of the tranny, do you pull this panel and drain it from there? If so, can a guy just use some Orange RTV gasket maker to seal it back up? Also can you use the Orange RTV to make gaskets for the diffs?
Old Jan 23, 2006 | 05:31 AM
The SnoMan's Avatar
The SnoMan
There should be a drain plug on it. Drain while warm after driving it some. THe D44 holds less than 3 qts.
Old Jan 23, 2006 | 05:37 AM
ford390gashog
you can pull that square panel off (its for the PTO option) .
Old Jan 23, 2006 | 09:12 AM
s8whiskey's Avatar
s8whiskey
The D44 holds 2 and 3/4 I just did mine but the D60 should key word by what my friend says it should hold aobut 3 1/2 4
Old Jan 23, 2006 | 11:08 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
i would jus tbuy 3 gallons of 80-90 and one of those quart sized squeeze bottles.....i always like to have extra when im done
Old Jan 23, 2006 | 11:15 AM
s8whiskey's Avatar
s8whiskey
Just get a little hand pump and the gallon and you are good to go.
Old Jan 23, 2006 | 05:45 PM
76f150_4x4_360fe
Yah 19.5 did sound high but thats what my chiltons said but that was for the cooling sytem, my bad
Old Jan 23, 2006 | 11:25 PM
ramboss429's Avatar
ramboss429
Just got all the fluids changed out, the D44 held about 2 1/2 quarts, the tranny held just at 4 I believe before it started pouring out, the D60 held just over 3 I believe. Wasn't keeping too good of count on the 60, got in a hurry.
Going to town with it tomorrow to get my exhaust bolted up. Gonna be running dual flowmaster 40s, from headers back $250.
hotrodjohn71
Oct 2, 2015 12:11 PM
Louie3
1997 - 2003 F150
Feb 27, 2012 08:34 PM
kystangbanger
Jan 16, 2010 08:48 AM
brownieboy525
Jul 9, 2006 05:54 AM
Gatsby
17
Jan 8, 2005 08:42 PM
