clutch vibration
Old Aug 14, 2001 | 11:40 PM
rngr70's Avatar
rngr70
clutch vibration
i had the clutch replaced about 3 months ago. it has kinda a shimmy or vibration when you let out the clutch from a standing stop. it is really noticable when i am reverse. is this something that can be adjusted out or is it normal till it get several miles on it? thanks for any help ben
Old Aug 14, 2001 | 11:50 PM
RubberDuck's Avatar
RubberDuck
clutch vibration
More than likely whoever did your clutch, didn't surface the flywheel. If you put a new clutch disk, and pressure plate on the same flywheel without surfacing it, it will still have the hot spots on it. Your new clutch will slip on them, and grab where it's not burnt. That will give you the jerking you are talking about.
Hope that helps.
RubberDuck
Old Aug 15, 2001 | 11:33 AM
6t6merc's Avatar
6t6merc
clutch vibration
That's called clutch chatter. I lived with it when I had a new clutch done a few years ago, and was determined to fix it when I had the engine out recently. I used a good quality clutch kit, had the flywheel resurfaced, and installed a new pilot bearing. It still chatters. I suspect a loose transmission bearing, but I'm not taking it apart again.
It's not normal, and it won't go away on its own.
Eric
Old Aug 18, 2001 | 06:19 PM
PetesPonies's Avatar
PetesPonies
clutch vibration
Worn engine mounts and worn transmission mount wil allw the clutch to grab and chatter.
Pete's Ponies
Mustang RUSToration & Performance
Old Aug 19, 2001 | 10:40 PM
Ratsmoker's Avatar
Ratsmoker
clutch vibration
Also a bad universal joint can casue this feeling.
Old Aug 20, 2001 | 07:38 AM
Raul's Avatar
Raul
clutch vibration
