no low beams
Old Jan 22, 2006 | 02:57 PM
1lowsplash's Avatar
1lowsplash
no low beams
i have a 95 ford ranger and i have high beams but no low. i have checked the relays and the fuses its all good but still no help. i think it might be the switch but if anyone can give me some info it would help out alot. i also have a rough idle not a clue what that could be.thanx
Old Jan 22, 2006 | 06:41 PM
dixiebronco1986's Avatar
dixiebronco1986
switch, wiring (broken wire or connection somewhere), light plugs (corroded or busted) , lights themselves,
Old Jan 22, 2006 | 08:29 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Jan 22, 2006 | 11:58 PM
cheez67's Avatar
cheez67
it would not be the headlamp switch. it may very well be the dimmer switch.
Old Jan 23, 2006 | 01:17 PM
Franklin2's Avatar
Franklin2
Probably is the dimmer switch, which may be built into the turnsignal switch(multi-function switch).
