Bronco II Ford Bronco II
Front end questions
Old Jan 22, 2006 | 01:31 PM
trvwilkins's Avatar
trvwilkins
Question Front end questions
Ive had my BII for about 6 years. In that time ive taken it to multiple shops to have the front end looked at. The right front side will never stay in alignment. Ive had bushings replaced, tie rod ends, bearings, etc. Always the same abnormal wear pattern. Outside edge of tire gets ground down. No problem at all with the left front, just right front. Any Ideas? Ive heard that the twin I-beam suspension was notorious for things like this.
Old Jan 23, 2006 | 11:07 AM
mrshorty's Avatar
mrshorty
When you say it won't stay in alignment, what specifically is going out: toe, camber, or caster? Do they manage to get all those things within spec when they do get it aligned? The TIB/TTB is not for the faint hearted/inexperienced alignment tech.
Old Jan 23, 2006 | 11:14 AM
trvwilkins's Avatar
trvwilkins
im really not sure how its out. The outside edge of the tread is constantly being ground down. Ive had it in multiple shops and they can't figure it out.
Old Jan 23, 2006 | 02:40 PM
oppy's Avatar
oppy
Unfortunately, tire edge wear is common with TTB equipped vehicles. The best way to assure good tire wear is frequent tire rotations.
Old Jan 23, 2006 | 03:28 PM
OSin86's Avatar
OSin86
do you have any extra hight added to the front? I've seen taller springs added without a drop kit in the center and that adds wear to the outside of the tires.
Old Jan 23, 2006 | 06:46 PM
trvwilkins's Avatar
trvwilkins
No, no added height in the front. Its stock suspension. What about converting to a straight axle front end? Is it possible?
Old Jan 24, 2006 | 10:14 PM
Desert Dog's Avatar
Desert Dog
front end
Go to a Les Schwab dealership they will tell you if it can be alighned or not.
Old Jan 25, 2006 | 12:09 AM
trvwilkins's Avatar
trvwilkins
umm, nearest les schab is about 4 hours away. Kind of out in the boonies.
