It won't start
Old Jan 22, 2006 | 11:16 AM
SWPoffice1's Avatar
SWPoffice1
Question It won't start
I have an 02 F350 7.3 that will not start. Here is the history. Fri AM went to a meeting that lasted about 1.5 hour, cam out to the truck and it would not start. Drained the fule filter, thinking that it is bad fuel, and it started. Drove 25 miles back to the office without problems. Stayed at the office for about 4 hours, went to leave and it would not start. Drained the fuel many times with no affect. When the truck was new the Camshaft sensor went out so I went ahead and replaced it yesterday, still nothing. I checked the voltage on the relay and it reads about 10 volts. It is in the 60's so cold is not an issue. One thing, I read that you should pull the #9 fuse under the hood before changing the Cam Sensor, I can't find an under the hood fuse box, so I disconnected the batteries. Where is the fuse box under the hood, maybe the #9 fuse is blown. I know with all of the brain power out there someone can help me out. Thanks SWP
Old Jan 22, 2006 | 11:40 AM
Beast12's Avatar
Beast12
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...88#post3272088 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
We are glad to have you. Hope you enjoy the site. Check out the various forums. Lots of great info for you.
Thread moved to 99-2003 7.3L Power Stroke Diesel forum.
See ya on the boards!
-Matt
Old Jan 22, 2006 | 01:19 PM
PSNut's Avatar
PSNut
First i ever heard of that...i replaced mine without pulling any fuse..no problems.
What vol do u read off the batteries? How's your oil level?
Nut
Old Jan 22, 2006 | 05:49 PM
marvinlong's Avatar
marvinlong
if your batteries are up and good try draining the fuel filter again and add a bottle of diesel fuel additive and see if it runs a while, maybe some nasty fuel. never heard of pulling fuse to replace CPS. good luck . might go over CPS and make sure its snug and plugged
Old Jan 22, 2006 | 06:14 PM
Fire Rooster's Avatar
Fire Rooster
I am going with a weak battery. Try testing them both, one bad cell will kill a diesel
Old Jan 22, 2006 | 07:24 PM
PSNut's Avatar
PSNut
One quick check on the batteries is to disconnect both batteries and check the voltage of each with a good meter. The readings should be close say+-400mV difference between the two. They should read approx. 12.5VDC individual.
Nut
Old Jan 23, 2006 | 06:05 AM
SWPoffice1's Avatar
SWPoffice1
Still Out
Thank you very much for the input. The batteries check out OK, and the oil level is good. Can someone tell me where the under to hood fuse box is?
Thanks
SWP
Old Jan 23, 2006 | 07:59 AM
guzzle92's Avatar
guzzle92
.......Can someone tell me where the under to hood fuse box is?
Thanks
SWP
02s do not not have an underhood fuse box.
