low idle speed
Old Jan 21, 2006 | 05:09 PM
bear1956's Avatar
bear1956
Talking low idle speed
I just picked up a 1990 f150 4x4 with 89,500 miles on it it starts good and runs really good but idles slow maybe 100 rpm slow, it has efi at ac. Also the guy I got from had a remote starter put in at a Ziebart dealer. any suggestions ?
Old Jan 21, 2006 | 06:28 PM
Popa Tim's Avatar
Popa Tim
I would start with checking the baseline timing and rpm. A Haynes or Chiltons manual would be a good book to get if you don't have one already.
Old Jan 21, 2006 | 06:46 PM
bear1956's Avatar
bear1956
thanks also this truck hasnt been used much in the last 6 months im going to drive it for a while, i put some injector cleaner in the tank and see if it helps,yes i have a manual. ty
Old Jan 21, 2006 | 06:49 PM
bear1956's Avatar
bear1956
also is there a way to adjust the throttle cable ?
Old Jan 22, 2006 | 03:14 PM
darren_5.8efi's Avatar
darren_5.8efi
i have a 89 5.8 and it idles really low and it will stall but my time is out but i have know idea what it should be set at does any one know and can u expalin how to get it to idle higher thanks darren
cweb
Bronco II
May 10, 2012 06:14 AM
rbulla
Jan 30, 2005 07:44 PM
visegrip
Nov 13, 2002 07:41 PM
bluesoftail
Aug 27, 2002 10:24 AM
w4imm
Jun 10, 2001 03:17 PM
