'78 Quadravan headers (Hedman doesn't work))
Old Jan 20, 2006 | 11:48 PM
Sinister's Avatar
Sinister
Anyone know what headers will not rub front drive shaft?
Just tried Hedmans ceramic coated RV headers. No dice.
Rubbing front drive shaft
Old Jan 23, 2006 | 03:27 AM
Qvan666's Avatar
Qvan666
Right now there is not much you can do for headers. No one makes a set for that application. Hooker used to, but have discontinued them.
I used Sanderson street rod (shorty/block hugger) headers on my 78 Qvan. I had to trim the right motor mount a little, and I wrapped the starter in a heat shield blanket, but so far so good.
I don't know if I will keep them or not, I have a LH hooker for the Qvan, and a RH hedman that I may put on so I can get the long tube.
You *may* be able to find the headers on ebay, but they don't show up often.
bob
Old Jan 24, 2006 | 07:37 PM
Sinister's Avatar
Sinister
Sandersons
I just ordered Sandersons FF461. The right header angles back and slightly down, I don't see how it could possibly interfere with motor mount. Do you have FF460 or FF461?
If I had long tubes, I'd sure put them on. If you decide to sell yours, keep me in mind.
Thanks for the reply.
Old Jan 24, 2006 | 08:35 PM
Qvan666's Avatar
Qvan666
I am not sure which model I have. They were given to me as a 460 ford block hugger. They do that well. Of course, about a month after I mounted them and fabbed up an exhaust, I found the long tubes.
Sorry I can't be more help.
bob
Old Jan 24, 2006 | 08:46 PM
Sinister's Avatar
Sinister
FF460's both sides turn straight down.
461's the drivers side turns straight down and the passenger goes almost straight back.
Old Jan 25, 2006 | 12:53 AM
Qvan666's Avatar
Qvan666
With that description, I have to FF460, or something very close to it. Both sides drop straight down.
bob
Old Feb 19, 2006 | 12:19 PM
2939jd's Avatar
2939jd
I have those on mine. Just take a pipe about the same size as the oulet and stick it in the end and give it a push. You can tweak them out just enough that they will clear. I'll send you a pic if you want.
Old Feb 19, 2006 | 06:05 PM
Sinister's Avatar
Sinister
please send pic
The Sanderson 461's do not fit, I am returning them.
I have ordered another set of the hedman's uncoated for modification purposes and a set of the thorley Tri-Ys. I figured modifying two tubes on the thorleys would be easier than four tubes on the hedmans.
I definitely want to see pic of yours.
Thanks,
Joe
Old Feb 19, 2006 | 06:14 PM
Sinister's Avatar
Sinister
please send pic
Thanks,
Joe
jdadamsjr
Jul 7, 2010 06:42 PM
i eat hybrids
Jan 29, 2007 09:08 AM
nothingbutford
Electrical Systems/Wiring
Apr 27, 2004 08:34 PM
Musicman250
Paint & Bodywork
Apr 11, 2004 09:04 PM
